 Post subject: WD10TMVV - Write Protected
PostPosted: June 20th, 2013, 6:12
HI,
WD Elements. With Write Protection.
According to owner explanation, the Drive suddenly disappeared during copy process. Then it can't be mounted.
Well, I have checked the HDD, it's detected normally, detected as Unallocated under device manager.
Checked by WinHex and reported it's Write Protected.
Any hints would be appreciated.
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
 Post subject: Re: WD10TMVV - Write Protected
PostPosted: June 21st, 2013, 5:19
shahij wrote:
HI,
Didn't get ,you checked hdd via USB or via Sata ?
And what means: Write protected? But reading from him is fine?
Angel Data Recovery
PostPosted: June 21st, 2013, 5:32
Read via USB. Victoria reports Write Protected. WinHex reports write-protected.
will replace with sata pcb today to check further.
__________
THANK YOU
SHAHI
PostPosted: June 21st, 2013, 11:45
islamm3rouf wrote:
u can replace the board with 771692 sata board
and move the rom ic
it will be fine
but forget your data
this is an known smartware encryption case
It is NOT .WD Elements don't use HW encryption. The problem is elsewhere. When topicstarter plug in drive dirrectly via SATA , all will become clear.
Angel Data Recovery
PostPosted: June 21st, 2013, 12:37
islamm3rouf wrote:
u need data from it
forget
u need to repair it
replace board with sata one
How can you be sure it is not 3,5" WD Element Desktop?
Angel Data Recovery
PostPosted: June 21st, 2013, 15:23
See subject.
PostPosted: June 21st, 2013, 15:44
See subject.
Ok , true. Missed that
Angel Data Recovery
PostPosted: June 22nd, 2013, 2:49
islamm3rouf wrote:
is this disk 2.5 inch
with smartware board USB3
It's 2.5"
USB 2.0
I didn't replace to SATA board yet. May be today will do it for inspecting further.
__________
THANK YOU
SHAHI
Users browsing this forum: Hardcore Games and 221 guests
