 Post subject: Howto Read FW in HITACHI HTS727550A9E364 Via Pc2k
PostPosted: June 21st, 2013, 9:51
Hi all gurus;
I have here for this drive:
HITACHI
HTS727550A9E364
500 GB 2,5" SATA 3.0
MLC: DA4217
PN: H2T5001672S 0J18811
APR-12
PCB STICKER: 0J14319 DA4730_ Pzy213 0RWM
I want to read drive FW with PC3K for get a copy off FW.
i can read secs (not using PC3K), Drive works fine, and in if i atach to PC3K it cames ready.
but PC3K do not recognize this model, and i can not start utility.
Any way to get FW in this case?
Thanks to all gurus.
Bye
 Post subject: Re: Howto Read FW in HITACHI HTS727550A9E364 Via Pc2k
PostPosted: June 21st, 2013, 10:28
Which pc3k do you have?
UDMA or PCI?
I don't think that the PCI version supports this drive, UDMA surely!
My firmware database:
PostPosted: June 24th, 2013, 7:56
Yep. UDMA supports it.
PostPosted: June 24th, 2013, 11:43
opss, i have UDMA version.
i atach pic
PostPosted: June 24th, 2013, 11:50
So you shouldn't have problems with that.
PostPosted: June 24th, 2013, 12:11
Ill try to update it. maybe any install problem
PostPosted: June 24th, 2013, 12:56
And is the hdd working fine?
PostPosted: June 24th, 2013, 13:00
Yes,
I explain de situation
I have a patient drive, i suppose bad heads, or bad FW.
I get a donnor drive, i wnat to make fw saving before start testing.
them Heads exchange. but PC3k do not recongnize bad drive, and not recognize donnor drive (this donnor drive works fine)
Thanks dmarkes for your help
PostPosted: June 24th, 2013, 14:23
Have you tryed ARM menu?
http://www.rescue-it.se
PostPosted: June 24th, 2013, 14:42
Hi mr_spokk;
ARM Menu?, what do you want to say?
PostPosted: June 24th, 2013, 15:09
HITACHI-IBM-ARM family below HITACHI-IBM, which is the default family
PostPosted: June 24th, 2013, 15:11
hhddrec wrote:
Hi mr_spokk;
I'm not at work right now, but I believe this drive is ARM.
PostPosted: June 24th, 2013, 17:17
Yep, I also think that's ARM (if I remember well).
PostPosted: June 25th, 2013, 5:56
Thanks dmarques and mr_spokk;
i send you a pic from PC3K
maybe my PC3K is wrong?
PostPosted: June 25th, 2013, 6:21
With that menu you don't have UDMA..only Pc3000....then you can forget to work with ARM drives.
Is it a nice Chinese version perhaps :mrgreen:
Should look like this:
PostPosted: June 25th, 2013, 6:22
No!, is an oficial version!
I do not untherstand!
PostPosted: June 25th, 2013, 6:33
Can you post here the version of PC3K.
PostPosted: June 25th, 2013, 6:55
Here is:
PostPosted: June 25th, 2013, 7:33
Most possibly this is an outdated UDMA version. When did you update it last? If more than a year ago, then you have old version and you need to update it.
PostPosted: June 25th, 2013, 7:58
5.2.6 is that latest as I know...go to your updatebox and upgrade.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 68 guests
