glhd wrote:
Vulcan wrote:
@glhd,
I don't understand exactly what you are now asking about regarding "suggestion on TTL device", but perhaps someone else understands / cares.
On Ebay I've found TTL device for 2 dollars, so I'm asking if one of these ultra cheap device will work or if is better to buy something better
Unfortunately you are making it difficult to help you, as "TTL device" is too vague to give an answer.
If you supply a link to whatever you are talking about, that will probably help.
All I will say is that
you have to take responsibility for
your decision to do DIY. I don't know how anyone can tell you if something from Ebay will "work", or not. It could be broken, or you might connect it wrongly, or X other possible problems. Or perhaps you are describing the right adapter and it works, but your drive has already been damaged by your decision to attach the drive to a PC serial port, and so whatever you get from Ebay might
appear not to work (although there are tests you can do). The point is that IMHO you are asking a hypothetical question, which is not possible for someone else to answer with confidence. Of course another member here might have a different view.
As I said a while ago, I was just trying to help by answering your earlier question. I could already see from the earlier part of the thread that there would be communication problems, so I'll stop here. Good luck
