 Post subject: WD7500KMVV-11A27S2 Failed firmware update
PostPosted: July 4th, 2013, 12:41
Have a WD7500KMVV-11A27S2 Failed firmware update with a failed firmware update.
Module 2E has a faulty header but everything else important seems fine. HD activity light just blinks constantly when plugged in but can communicate via serial fine. Heads 0 and 1 test out fine on PC3K. OK to try replacing 2E on this drive or any other ideas?
 Post subject: Re: WD7500KMVV-11A27S2 Failed firmware update
PostPosted: July 4th, 2013, 15:28
Can you read sectors in pc3k util?
PostPosted: July 5th, 2013, 7:15
What about ROM ?
PostPosted: July 5th, 2013, 9:39
Yes, i can actually read all sectors. Obviously encrypted.
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 6
Cyl Count............................... : 256
Zone allocation table................... : Ok
SA SPT.................................. : 905
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 192 Kb
ROM version............................. : 81.D6E
ROM generation.......................... : 81.D7E
Link table version...................... : 05.C3.
Consolidated ROM version................ : 008100D6
ROM Modules:
Flash ROM dir reading................... : Ok
Flash ROM dir (ext) reading............. : Ok (Active)
Modules directory address............... : 171 421 (24)
SA regions address...................... : by default
SA Translator loading................... : Ok
Heads configuration..................... : by map
Heads number in use..................... : 6
Switched off heads...................... : No
Heads map............................... : 0,1,2,3,4,5
ROM Firmware version.................... : 008100D6
Service area:
SA dir reading (ID)..................... : Ok
SA Access............................... : Copy 0,Copy 1
Configuration reading................... : Ok
Master Password......................... : has not been set
User Password........................... : has not been set
Being detected as WD SES device in windows but thats as far as it goes. Will try resetting SMART once resources are eventually backed up
PostPosted: July 6th, 2013, 8:53
No luck. Anyone have Module 2E from a WD7500KMVV-11A27S2 firmware 01.01A01?
Users browsing this forum: No registered users and 173 guests
