 Post subject: HITACHI HTS727550A9E364 Bad Secs in SA writing problems
PostPosted: July 11th, 2013, 7:27
Any way to Write sectors in IBM-ARM Architecture if secs in SA badly
I have a HTS727550A9E330 with PSHT copy1 badly, i tryed to write form PSHT copy0 witout success.
Any way
Thanks in advanced
 Post subject: Re: HITACHI HTS727550A9E364 Bad Secs in SA writing problems
PostPosted: July 11th, 2013, 9:37
And do you really need a good PSHT copy1?
Can't you have sector access?
PostPosted: July 11th, 2013, 10:56
Yes, i have access to Secs but i can only access from sec=0 to to sec=602279
them i get error reading secs.
PostPosted: July 11th, 2013, 11:07
i atach pics about case
PostPosted: July 11th, 2013, 11:16
Needs a head swap, as at least h1 is toast.
Suggest not powering on as is. These are easily prone to further damage when trying to image working heads first. Got one right now. Wasting parts on it...
PostPosted: July 11th, 2013, 11:51
before had heads problem, but now is head exchanged.
I think problem is about FW
PostPosted: July 11th, 2013, 12:16
I am trying to read secs to 10.000.000 but no success in any of them in advanced to sec=602279.
If them problem is any head must i can read other secs areas.
PostPosted: July 11th, 2013, 17:00
This is new ARM hitachi drive. Problem can be solved, but, i am afraid, you have to send it.
If you check PSHT module in RAM , it is empty.
Angel Data Recovery
PostPosted: July 12th, 2013, 10:11
Hi DR-Kiev.
If this is a question:
Yes, the PSHT module in RAM is empty
PostPosted: July 12th, 2013, 10:34
i atach log From PC3k:
Test : Resource master copy creation in DB
Folder: /727550/Hitachi HTS727550A9E364 JF3O0E01 J3300080GVY1XA
ROM reading............................. : Ok
Reading ROM to DB (ROM/ROM.bin)....................................... : Ok
Reading NV-RAM to DB (NV-RAM/...)...
NV-RAM.nvr...
NV-RAM_0.nvr...
NV-RAM_1.nvr...
NV-RAM_2.nvr...
NV-RAM_3.nvr...
NV-RAM_4.nvr...
Reading NV-RAM to DB (NV-RAM/...)..................................... : Ok
Off-line start resources
Main modules table.................................................... : Ok
"Open" modules table.................................................. : Ok
Reading modules to DB
Folder: <root>/Hitachi-IBM-ARM Utility/727550/Hitachi HTS727550A9E364 JF3O0E01 J3300080GVY1XA/Modules
Module RPSH Copy 0...................... : Ok
Module RPSH Copy 1...................... : Ok
Module USAG Copy 0...................... : Ok
Module USAG Copy 1...................... : Ok
Module RAMI Copy 0...................... : Ok
Module RAMI Copy 1...................... : Ok
Module RAM0 Copy 0...................... : Ok
Module RAM0 Copy 1...................... : Ok
Module PSHT Copy 0...................... : Ok
[color=#FF0000]Error transferring command data: Reading SA [0x3F0101400, 0x40]
HDD Data timeout
Error executing command: Reading SA [0x3F0101401, 0x1]
Device error detected (UNC)
Error................................................................. : Error executing command: Reading SA [0x3F0101401, 0x1]
Loading : PSHT, P-List module......................................... : Error
Module PSHT Copy 1...................... : Error[/color]
Module RDMT Copy 0...................... : Ok
Module RDMT Copy 1...................... : Ok
Module RPOP Copy 0...................... : Ok
Module RPOP Copy 1...................... : Ok
Module SECI Copy 0...................... : Ok
Module SECI Copy 1...................... : Ok
Module SECB Copy 0...................... : Ok
Module SECB Copy 1...................... : Ok
Module ZONE Copy 0...................... : Ok
Module ZONE Copy 1...................... : Ok
Module SRVP Copy 0...................... : Ok
Module SRVP Copy 1...................... : Ok
Module SRVM Copy 0...................... : Ok
Module SRVM Copy 1...................... : Ok
Module CHNM Copy 0...................... : Ok
Module CHNM Copy 1...................... : Ok
Module IDNT Copy 0...................... : Ok
Module IDNT Copy 1...................... : Ok
Module SMRT Copy 0...................... : Ok
Module SMRT Copy 1...................... : Ok
Module SERL Copy 0...................... : Ok
Module SERL Copy 1...................... : Ok
Module IOPS Copy 0...................... : Ok
Module IOPS Copy 1...................... : Ok
Module SSLD Copy 0...................... : Ok
Module SSLD Copy 1...................... : Ok
Module SCTH Copy 0...................... : Ok
Module SCTH Copy 1...................... : Ok
Module FEAT Copy 0...................... : Ok
Module FEAT Copy 1...................... : Ok
Module CNFG Copy 0...................... : Ok
Module CNFG Copy 1...................... : Ok
Module WWNM Copy 0...................... : Ok
Module WWNM Copy 1...................... : Ok
Module RPSP Copy 0...................... : Ok
Module RPSP Copy 1...................... : Ok
Module SPTR Copy 0...................... : Ok
Module SPTR Copy 1...................... : Ok
Module ABLP Copy 0...................... : Ok
Module ABLP Copy 1...................... : Ok
Module DBGC Copy 0...................... : Ok
Module DBGC Copy 1...................... : Ok
Module ALSM Copy 0...................... : Ok
Module ALSM Copy 1...................... : Ok
Module ATIR Copy 0...................... : Ok
Module ATIR Copy 1...................... : Ok
Module AVZN Copy 0...................... : Ok
Module AVZN Copy 1...................... : Ok
Module CGDF Copy 0...................... : Ok
Module CGDF Copy 1...................... : Ok
Module ELG1............................. : Ok
Module EVLG............................. : Ok
Module PID1............................. : Ok
Module PID2............................. : Ok
Module PIDM............................. : Ok
Module HLR1............................. : Ok
Module HLR2............................. : Ok
Module MFGP............................. : Ok
Module AMPM............................. : Ok
Module MFGT............................. : Ok
Error transferring command data: Reading SA [0x3F0010700, 0x40]
HDD Data timeout
Error startintg command: Reading SA [0x3F0010701, 0x1]
Error................................................................. : Error startintg command: Reading SA [0x3F0010701, 0x1]
Loading : DMP1,....................................................... : Error
Module DMP1............................. : Error
Module SDM1............................. : Ok
Module SVLG............................. : Ok
Module DDD0............................. : Ok
Module DIAG............................. : Ok
Module WRT0............................. : Ok
Module WRT1............................. : Ok
Error startintg command: Reading SA [0x3F0212700, 0xF]
Error startintg command: Reading SA [0x3F0212700, 0x1]
Error................................................................. : Error startintg command: Reading SA [0x3F0212700, 0x1]
Loading : WRT2, Marker at head 2...................................... : Error
Module WRT2............................. : Error
Modules reading completed
Saving modules by copies.............................................. : Error
Saving SA report to file SAReport_0_1_F.txt
Module checking
Reading modules to DB (composite)
Module RPSH............................. : Ok
Module USAG............................. : Ok
Module RAMI............................. : Ok
Module RAM0............................. : Ok
Module PSHT............................. : Ok
Module RDMT............................. : Ok
Module RPOP............................. : Ok
Module SECI............................. : Ok
Module SECB............................. : Ok
Module ZONE............................. : Ok
Module SRVP............................. : Ok
Module SRVM............................. : Ok
Module CHNM............................. : Ok
Module IDNT............................. : Ok
Module SMRT............................. : Ok
Module SERL............................. : Ok
Module IOPS............................. : Ok
Module SSLD............................. : Ok
Module SCTH............................. : Ok
Module FEAT............................. : Ok
Module CNFG............................. : Ok
Module WWNM............................. : Ok
Module RPSP............................. : Ok
Module SPTR............................. : Ok
Module ABLP............................. : Ok
Module DBGC............................. : Ok
Module ALSM............................. : Ok
Module ATIR............................. : Ok
Module AVZN............................. : Ok
Module CGDF............................. : Ok
HDD Data timeout
Saving modules (composite)............................................ : Error
Backup of service information completed
Then in red we can see mods with errors:
PSHT Copy 1. - P-List
Maybe not needed because we have "PSHT Copy0" fine.
DMP1 -Unknown module
I do not know info about this module, maybenot important
WRT2 - Marker at head 2.
maybe here is the problem
What you think?
PostPosted: July 12th, 2013, 10:51
I am testing
this is the head map of HDD.
HEad Number:
3
HEadMap:
00 01 02 0F 0F 0F 0F 0F 0F 0F
PostPosted: July 12th, 2013, 10:52
As Dr. Kiev told you, I don't think no one will tell you how to do it.
Specially as that is something that only a few people know about yet.
PostPosted: July 12th, 2013, 10:53
but if i change HEAD map:
HEad Number:
1
HEadMap:
00 0f 0f 0F 0F 0F 0F 0F 0F 0F
i can acess from sec=0 to 195551
HEad Number:
2
HeadMap:
00 01 0F 0F 0F 0F 0F 0F 0F 0F
i can acess from sec=0 to 418751
PostPosted: July 12th, 2013, 10:54
HEad Number:
3
HeadMap:
i can acess from sec=0 to 602279
PostPosted: July 12th, 2013, 11:35
then the problem is probably in WRT2 Marker
if this module have problems HDD do not know where change the working head.
what yiou think
have you got FW HITACHI HTS727550A9E364?
thanks
PostPosted: July 16th, 2013, 7:05
I can see to problems to write secs.
I tryed to write secs in User Area and i can not.
What you think? Heads problems? or other Problem?
PostPosted: July 16th, 2013, 10:57
i update case with a pic
what you think about lined in red Area? scrached?
PostPosted: June 24th, 2024, 1:33
I mean 10 years have passed. I am encountering this problem my self. and yet no one want to post any solutions into this post. So sad :cry: :cry: :cry:
PostPosted: June 24th, 2024, 6:38
PSHT module s responsible for LBA access. If that module does not work then there is no LBA access.
Solution: solve the PSHT module problem.
How? Try to read each PSHT copy at the time, then patch together the module as best as possible in one good module, fill any 00s error gaps and see if it works.
Further problem? The module likely cannot be written back to the drive, so it will have to be loaded in RAM.
Has this been tried already?
Users browsing this forum: No registered users and 66 guests
