 Post subject: Seagate 250GB Terminal Rst 08M Buzz
PostPosted: July 15th, 2013, 3:48
Dear Respected Members
please advice with your kind suggestion what could be the problem i am getting below error message in terminal mode while hard disk shows busy all the time and there is no sound
Seagate Momentus 5400.4
250GB
Terminal Error
Rst 08M
Buzz
Buzz
Buzz
Buzz
when i press CTRL +Z it gives me F> and start the Buzz again
f>
Buzz
Buzz
Buzz
thanks
 Post subject: Re: Seagate 250GB Terminal Rst 08M Buzz
PostPosted: July 15th, 2013, 4:01
Sticktion...
http://www.rescue-it.se
PostPosted: July 15th, 2013, 4:09
Sticktion...
Many Thanks mr_spokk
what will be the solution ?
PostPosted: July 15th, 2013, 4:41
azzan wrote:
Sticktion...
Your occupation is listed as 'Data Recovery Expert' yet you do not know about stiction?
Outsource it.
PostPosted: July 15th, 2013, 5:06
I wonder if "no sound" is really "no sound" or is "hear something from the hdd" .... it's different !
PostPosted: July 15th, 2013, 6:30
Have you opened the drive?
PostPosted: July 15th, 2013, 6:37
only spinning sound come
no i did not open the drive yet
Sticktion... this is the 1st case to me
PostPosted: July 15th, 2013, 7:18
then outsource it before you open to keep costs down, get the data recovered as a priority, then once data is safe ask client if you can keep drive for 'spares' and you can experiment with it after
PostPosted: July 15th, 2013, 7:57
I give up. "spinning sound" to me means the drive is spinning, but terminal says otherwise... If you hear a series of ATTEMPT TO SPIN, is one thing. If it spin up and down, another.
PostPosted: July 17th, 2013, 5:20
To be sure about stickion. you must open HDD case in a clean room
but is you are not familiarized, better outsource this case a said HDDGuy
Users browsing this forum: Lukas and 200 guests
