 Post subject: Another dead WD 5000BMVW-11AMCS0
PostPosted: July 15th, 2013, 19:17
Hi Guys,
I have another WD 5000BMVW-11AMCS0 which seems to be dead. Drive's light lights up once connected, and drive tries to start to spin 5 times with a slight buzzing noise until it gives up.
Got detected initially unden Windows as WD Ext Disk but was not appearing under device manager. Under Ubuntu it does not appear under /dev or Disks GUI.
Could swaping PCB and ROM, solve this issue?
Thanks again!
 Post subject: Re: Another dead WD 5000BMVW-11AMCS0
PostPosted: July 15th, 2013, 20:04
No, seems the problem is internal. Seems like heads may have gotten stuck on the platters. Need good technique to resolve that if that is indeed the problem.
PostPosted: July 16th, 2013, 2:51
Outsource the job if no CR and tooling available.
PostPosted: July 16th, 2013, 3:27
Hi
Happy to take a look if you want.
Evaluation is free.
PostPosted: July 17th, 2013, 2:04
gulliver wrote:
Hi Guys,
Thanks again!
I have a drive that is sounding like doing similar to yours. I have just got back from travel and not had time yet to continue working on my drive after the helpful guys posted for me.
does it sound anything like the sound I posted here? just curious.
http://malthus.zapto.org/viewtopic.php?f=3&t=569
cheers
PostPosted: July 19th, 2013, 14:45
Im so sorry I havent replied yet. Very busy week and I thought I had subscribed to be notified by email...
anyway... yes the sound is like your other post. I havent got the time to look into it any further. Did you get any results? I have the soldering equipment and skils but is it the right direction?
My friend has already asked for pro help and she wont go for the 500EUR suggestion. To be honest she does not have the money (unemployed for several months) and the drive has only pictures so I offered her my help free of charge just to help her. She knows I'm not a guarranteed helping hand but I will not just try trial error.
So yes, I was just asking the community if there was an almost free way to help her but from what you said I think the answer is no.
PostPosted: July 22nd, 2013, 3:20
It sounds like a stiction fault (heads stuck to platters).
This guy was lucky:
viewtopic.php?t=26458&p=180863#p180863
PostPosted: July 22nd, 2013, 4:59
... and a trillion others weren't.
PostPosted: July 22nd, 2013, 5:19
:lol:
PostPosted: July 22nd, 2013, 5:56
Percussive maintenance (AKA the Cozy Powell Fix :lol: )... Very rarely works, and generally causes MORE damage to the drive heads and platters..
http://www.eadr.co.uk
PostPosted: July 22nd, 2013, 6:07
Call it properly : BANG THE HDD more or less rudely on the table / desktop or whatever hard surface....
I knew it as the "Wile E. Coyote" fix , missed the Cozy Powell definition !
PostPosted: July 22nd, 2013, 6:10
Must be showing my age.... http://en.wikipedia.org/wiki/Cozy_Powell :lol: :lol:
PostPosted: August 5th, 2013, 15:27
Thank you guys! I finally managed to scare her enough and try to do some savings and try later a Pro. She only has one shot and better make the most of it.
Thanks again!
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 57 guests
