Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
 Post subject: Re: Help With Data Recovery For An External Drive
PostPosted: October 24th, 2012, 9:16
TheRedMaverick wrote:
Well I did another scan for the G partition like drc suggested. It seems to be almost identical to the FAT32 partition from the original scan except in the metadata, it says the partition offset is 0 bytes instead of the original scan showing 1MB (2048 sectors) and the new scan shows one more parsed file entry than the original scan.
It doesn't pick up a red NTFS partition like the first time?
PostPosted: October 25th, 2012, 22:58
Unfortunately, no. Not sure why that is but it could be an indicator that the partition is more damaged than I suspected. I ordered a new external drive and I'm going to make a clone of the original one with it
PostPosted: July 18th, 2013, 0:41
Well gentlemen, the issue has been resolved. This is a pretty late update (considering my last post was in October of 2012). I'm updating the topic just in case anyone ever stumbles upon a similar issue and needs help.
After my last post, I sort of gave up and forgot about it for a while. I decided a couple of days ago to start back up again to try to fix the issue. Testdisk by CGSecurity is the application that really worked wonders. Instead of recovering the raw files, I used Testdisk's analyze mode to find my damaged NTFS partition. I then overwrote my boot sector with my backup boot sector and then performed a chkdsk /r in command prompt to recover my files.
The entire process I followed can be found here
After doing the above, my hard drive was still corrupted so I had to perform chkdsk /r. You may or may not have to do this depending on your situation.
Thanks for all the help and support in this thread!
PostPosted: July 18th, 2013, 1:00
Glad you managed to get your data back. :)
For the benefit of anyone else finding this thread in future - do not do the same as the (lucky) OP here, by changing the original drive using Testdisk and chkdsk. In both cases, the changes are typically irreversible, so if they make things worse, then you're stuck with that! Typical advice would have included discussions about cloning, as was suggested earlier on, but needs to be considered on a case-by-case basis, depending on the drive's symptoms, how the original problem was caused etc.
Anyway, as I said, glad you were successful. :)
PostPosted: July 18th, 2013, 1:01
This was interesting case. Can you define "resolved" a bit more? What is the final outcome as far files recovered working? Corruption? Etc.
PostPosted: July 19th, 2013, 0:09
Good point about attempting this on a cloned drive, Vulcan. For me personally, if the drive became damaged beyond repair, I would've just accepted the loss of data. For those who have extremely important information, definitely follow Vulcan's advice.
Well, labtech, as far as I can tell, most of the files I've tested work perfectly without any corruption. I haven't tested every file yet but things are looking good so far. The only issues I can express are that I'll get the occasional message that says the recycle bin of the drive is corrupt and should be formatted and one time it said that the entire drive needs to be formatted to be used; I didn't format but all the files disappeared and I had a mild heart attack but, after restarting the PC, they reappeared.
PostPosted: July 19th, 2013, 7:47
Strange, but great. Successful outcome. Would recommend making a new spanking backup of the files onto a stable newly formatted drive.
PostPosted: July 20th, 2013, 4:00
I definitely will :D
Users browsing this forum: pepe, Pi0tR and 82 guests
