 Post subject: toshiba MK1656GSY strange behaviour
PostPosted: July 22nd, 2013, 17:43
good evening ;
i have got this toshiba drive , when trying to image using ddi4 , drive gets ready and identify with the correct serial and capacity ,
trying to do head map , will result in drive stuck at BSY
sending "drive preconfiguration" will complete after ~50 secs with no smart errors
trying to test media will start , but will take foreever
i could image the first 8% of it at ~55000 KB/SEC, but then the drive just freeze at BSY , no abnormal sounds , or anything ,
the drive just behaive very similar to the pending bug for seagates ..
now , drive , stopped imaging at all , and freezes at BSY when trying to image ..
any ideas ?
thank you
 Post subject: Re: toshiba MK1656GSY strange behaviour
PostPosted: July 22nd, 2013, 19:00
Use the PC3000 instead, which has several features for working with Toshiba drives with G-List problems, etc.
http://www.datasaversllc.com
PostPosted: July 22nd, 2013, 20:15
Yeah, agree with Jono. Have to check on that g-list.
PostPosted: July 22nd, 2013, 20:24
PC3K is great at recovering Toshiba drives with g-list problems.
PostPosted: July 23rd, 2013, 11:22
thank you for your help ..
so this is 100% a g-list problem .
unfortunately , i donut have PC3K , any way i can extract some portions of the disk , or just have to outsource it ?
PostPosted: July 23rd, 2013, 12:12
Not 100%, but assume as likely one of the main issues. Again, this is remote suggestion as we do not have the drive in our hands.
PostPosted: July 24th, 2013, 7:14
have you tried reverse cloning ?
data recovery Poland
PostPosted: July 24th, 2013, 9:42
Not 100%, but see many Toshiba with this issue.
Without PC3K, you are going to struggle, BIG TIME :-(
Users browsing this forum: Google [Bot] and 48 guests
