 Post subject: Looking PCB for TOSHIBA MK5055GSX - HDD2H21 C WL01 S
PostPosted: July 23rd, 2013, 5:18
Hello I need a PCB compatible with this Toshiba Harddisk:
TOSHIBA MK5055GSX - HDD2H21 C WL01 S.
PCB Number G002439-0A,
Controller Chip: 88I8817D-BHJ2
Firmware: 010 A0/FG001A
The drive Powered no spinning no sound at all (silent). I think could be dead PCB or blown fuse.
 Post subject: Re: Looking PCB for TOSHIBA MK5055GSX - HDD2H21 C WL01 S
PostPosted: July 25th, 2013, 7:30
Check the fuse first :-)
Post a pic if you don't know where it is.
PostPosted: July 25th, 2013, 17:08
Thanks, the PCB is the same like this link viewtopic.php?t=19939&start=
but i don't Know how can i change the fuse, and where can i buy a new one. The fuse surface is labeled "S".
Thanks again
PostPosted: July 25th, 2013, 17:27
Follow my instructions in that link. Farnell is one supplier. You could probably find it at Mouser and Digikey, also. However, do some resistance testing first. Do you have a multimeter? If not, a DMM should cost you less than US$10. I can help you with the test points.
PostPosted: July 27th, 2013, 13:39
Thanks for the info. I'll do resistance test first.
