Post new topic Reply to topic  [ 898 posts ]  Go to page Previous  1 ... 32, 33, 34, 35, 36, 37, 38 ... 45  Next
 Post subject: Re: Unlocking ATA Password for Western Digital
PostPosted: July 18th, 2013, 17:14
Anyone? Come on guys, I don't have the time to look at the problem myself because of my bachelor-thesis...that's a little bit more important at the moment, but I'd like to solve this problem rather sooner than later ^^ otherwise I've got to wait til I have some free time again...
PostPosted: July 19th, 2013, 0:11
Apparently I can't use ZU either, it's a 2.5" drive.
so what ? :roll: zu works with 2.5 disks
PostPosted: July 19th, 2013, 10:14
hellow dp i want ur help for hitachi drive i have a sata dirve for laptop can u plz tell me how can i remove this pass hope u ill be help me thanks for advance dmitry postrigan :)
PostPosted: July 19th, 2013, 18:55
@Moltke: huh, did I miss something? oO as far as I knew, zu didn't support 2.5inch drives, I read it several times in here (even superloadedcat posted it at the top of this page). Did they change something or am I just wrong?^^
PostPosted: July 22nd, 2013, 18:18
superloadedcat wrote:
zu doesn't support 2.5 inch drives.
:shock: Sorry, you are WRONG.
_zu.betta.050911.rar
DOES unlock 2.5" drives :lol: .
Example:
2.5" Toshiba MK1031GAS (100GB PATA) with 44 to 40 pin adapter on an ASUS P4B533 mainboard primary master configured.
(took less than a second :mrgreen: - this mainboard cannot boot from USB, i used a floppy drive :D :D :D ).
So please stop posting this :!:
PostPosted: July 23rd, 2013, 0:20
so there! :-)
PostPosted: July 24th, 2013, 15:43
Okayokayokay, I was wrong, I'm sorry :D
As I already mentioned, I don't really have the time to test it in detail at the moment (stupid thesis!). But as far as I got it, I have to mount the hdd to the primary or secondary port and then let zu do the magic? Because I already tried something like that, in fact I plugged it into the very first sata-port (I don't really know which other 'primary' I should take) and booted zu from a floppy. It didn't report any error, but even after 2 hours (as displayed) there was no unlock done. I guess I did something wrong...? Sometimes I'm a real derp, when it comes to hardware x)
PostPosted: July 26th, 2013, 10:27
well, even without any drive other than the floppy attached, zu doesn't report any error...I'm getting a headache...
PostPosted: August 3rd, 2013, 11:09
Is there any way to dump the modules that contain the password other than those mhdd-scripts? Mhdd doesnt recognize my hdd :?
PostPosted: August 5th, 2013, 18:40
Hey guys, long-time lurker first time posting here, though. So much good info on this board, it's just too bad I haven't had much to contibute, yet. Here's the 22.bin file for an old friend of mine's laptop to which he forgotten his password, for. It was set with PhoenixBIOS on his gateway D620 to a WD1600BEVT.
I've seen alot of "please find my password!!!111" stuff on here, and I feel a bit bad for joining in the fray, but I feel like I have done all I can on my own, to prevent myself from doing this =(
My offset looks a bit goofy compared to other bin files I've seen on here, and I've tried saving that selection with UltraEdit and unlocking with Victoria, but no dice. I'm wondering if I'm just selecting too much, or just too far beyond my scope. Thanks for the help guys, I'm glad to finally be a part of the forum ^_^
PostPosted: August 6th, 2013, 2:49
unknown wrote:
if u have pc3000 use it to unlock ur hard drive
Dear Friend Unknown
I Like Your Signature. (A fool with a tool is still a fool.)
Its Realy True.
PostPosted: August 16th, 2013, 19:16
Bump see if anyone has read my post above, or do I need to provide additional info? :D Let me know, please.
PostPosted: August 17th, 2013, 22:58
PM Sent
PostPosted: August 18th, 2013, 16:49
ROb wrote:
PM Sent
Sorry I guess I need more activity to reply to PM's, are you saying to use MHDD instead of Victoria to input the hex? The selection I have highlighted, converted to ASCII, is apparently 20304050607000000000000, which doesn't appear to be anything. Most other tables I've looked at, I've been able to spot the 01 07 00 header and see how a key was discerned, but mine seems a bit odd.
Using tables like this one
Am I headed in the right direction, here?
PostPosted: August 19th, 2013, 11:57
aixadmin wrote:
Well, I gave it another go and it must have been in a better mood this time as it populated the .bin files but these look very different from those posted above. I've attached zips of both a locked and unlocked drive. Anyone have suggestions for decoding them?
MHDD info for unlocked drive.
8.12.2010 20:43:41 MHDD>EID
8.12.2010 20:43:41 WDC WD2500JD-00FYB0 LBA: 488,397,168
8.12.2010 20:43:41 SN: WD-WMAEH1377067 FW: 02.05D02
you password is:
PostPosted: August 19th, 2013, 12:44
sergiopedrola wrote:
Hello I generated a mod with mvr_r and I dont know what is my password.
00000000  52 4F 59 4C 01 00 30 00 02 00 03 00 6D C1 27 63  ROYL..0.....mÁ'c
00000010  30 30 30 38 30 30 30 30 0A 07 08 00 00 00 00 00  00080000........
00000020  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000030  1C 00 A2 00 16 00 B8 00 18 00 D0 00 26 00 F6 00  ..¢...¸...Ð.&.ö.
00000040  33 00 8F 01 0C 00 9B 01 12 00 BF 01 04 00 C3 01  3.....›...¿...Ã.
00000050  06 00 C9 01 13 00 DC 01 11 00 ED 01 27 00 14 02  ..É...Ü...í.'...
00000060  12 00 26 02 20 00 46 02 39 00 7F 02 0D 00 8C 02  ..&. .F.9.....Œ.
00000070  0E 00 9A 02 2E 00 C8 02 46 00 0E 03 48 00 29 01  ..š...È.F...H.).
00000080  33 00 5C 01 33 00 AD 01 12 00 56 03 10 00 66 03  3.\.3.....V...f.
00000090  0E 00 74 03 56 00 CA 03 1A 00 E4 03 1D 00 01 04  ..t.V.Ê...ä.....
000000A0  02 00 00 01 57 44 2D 57 58 45 39 30 38 53 33 37  ....WD-WXE908S37
000000B0  36 37 34 00 00 00 00 00 00 01 10 3F 00 00 00 00  674........?....
000000C0  AF EA 42 25 AF EA 42 25 AF EA 42 25 AF EA 42 25  ¯êB%¯êB%¯êB%¯êB%
000000D0  00 01 A4 03 00 00 00 00 07 7F 00 00 06 F4 01 01  ..¤..........ô..
000000E0  10 01 00 0C 08 01 64 00 00 00 00 01 0A 14 00 00  ......d.........
000000F0  00 14 00 00 00 01 00 01 01 00 40 00 40 01 32 00  ..........@.@.2.
00000100  05 07 00 01 00 02 80 00 3C 00 80 00 00 80 08 10  ......€.<.€..€..
00000110  0A 05 0A 24 2E 42 5F 78 80 80 00 08 00 05 03 00  ...$.B_x€€......
00000120  02 00 03 06 00 08 00 04 0F 00 01 01 00 C8 00 00  .............È..
00000130  04 32 00 05 07 00 01 00 02 80 00 C8 00 80 00 00  .2.......€.È.€..
00000140  80 08 10 0A 05 0A 14 28 5F 5F 78 80 80 00 08 00  €......(__x€€...
00000150  05 03 00 02 00 05 06 00 08 00 10 0F 00 01 01 00  ................
00000160  C8 00 00 04 32 00 05 07 00 01 00 02 80 00 C8 00  È...2.......€.È.
00000170  80 00 00 80 08 10 0A 05 0A 14 28 5F 5F 78 80 80  €..€......(__x€€
00000180  00 08 00 05 03 00 02 00 10 07 00 08 00 10 0F 00  ................
00000190  01 00 01 00 01 02 0A 0B 07 05 02 00 01 02 06 02  ................
000001A0  00 00 02 06 00 00 06 04 00 03 02 00 16 00 01 02  ................
000001B0  06 02 00 00 02 03 00 00 06 06 00 05 0A 00 16 00  ................
000001C0  01 01 01 00 01 14 64 00 00 00 01 64 00 00 4E 00  ......d....d..N.
000001D0  00 7E 00 00 07 01 78 03 00 64 00 00 00 03 84 7C  .~....x..d....„|
000001E0  D0 00 0A 00 14 3C 40 00 01 04 0A FA 00 00 01 0E  Ð....<@....ú....
000001F0  00 00 00 02 02 00 0F 32 0C CA FA 0A 32 0A 01 3C  .......2.Êú.2..<
00000200  55 00 01 00 00 20 00 64 00 00 BA 00 19 01 00 00  U.... .d..º.....
00000210  00 00 00 00 00 01 60 02 12 00 22 00 0A 00 00 00  ......`...".....
00000220  00 00 00 01 01 00 00 01 E0 01 0F 0F 01 02 02 0A  ........à.......
00000230  01 02 00 02 02 08 01 00 FF FF 02 03 50 01 1E 64  ........ÿÿ..P..d
00000240  01 11 04 40 0B 02 00 01 00 00 00 00 05 00 00 00  ...@............
00000250  00 00 FF FF 00 00 00 00 12 0A 12 00 00 00 05 00  ..ÿÿ............
00000260  00 00 00 00 1E 00 00 00 00 00 00 00 00 00 4D 00  ..............M.
00000270  29 00 07 00 12 2E 00 00 00 0E 00 00 00 00 05 00  )...............
00000280  01 00 00 00 00 00 00 07 00 01 02 0D 00 01 03 00  ................
00000290  03 01 00 01 00 00 00 00 00 00 00 01 57 44 43 20  ............WDC
000002A0  57 44 33 32 30 30 42 45 56 54 2D 32 32 5A 43 54  WD3200BEVT-22ZCT
000002B0  30 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20  0
000002C0  20 20 20 20 20 20 20 20 00 01 53 7C 42 7C 4C 7C          ..S|B|L|
000002D0  50 5A 4D 53 48 47 43 4B 52 5A 56 41 4B 51 55 41  PZMSHGCKRZVAKQUA
000002E0  00 20 20 20 20 20 20 20 20 20 20 20 20 20 31 30  .             10
000002F0  2D 30 36 2D 32 30 30 38 00 00 00 00 00 00 00 00  -06-2008........
00000300  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01  ................
00000310  07 00 24 00 16 00 20 00 17 00 14 00 00 00 00 00  ..$... .........
00000320  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000330  00 00 53 00 1C 00 00 00 00 00 00 00 00 00 00 00  ..S.............
00000340  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000350  00 00 08 40 01 00 00 01 30 00 00 05 00 64 00 14  ...@....0....d..
00000360  20 32 00 00 00 0F 00 01 02 00 00 01 78 00 32 00   2..........x.2.
00000370  20 00 55 FF 00 01 00 00 00 00 00 00 00 00 00 00   .Uÿ............
00000380  00 00 00 00 00 00 00 00 00 00 00 00 00 00 58 58  ..............XX
00000390  58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58  XXXXXXXXXXXXXXXX
000003A0  58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58  XXXXXXXXXXXXXXXX
000003B0  58 58 58 58 58 58 58 58 58 58 58 58 58 58 01 01  XXXXXXXXXXXXXX..
000003C0  01 01 01 00 00 00 00 00 00 00 00 00 00 01 FF FF  ..............ÿÿ
000003D0  FF FF FF FF FF FF 00 00 00 00 00 00 00 00 80 00  ÿÿÿÿÿÿ........€.
000003E0  00 00 00 00 00 01 02 05 10 27 00 00 88 13 00 00  .........'..ˆ...
000003F0  00 00 D0 07 00 00 88 13 00 00 1E 00 00 00 05 D6  ..Ð...ˆ........Ö
00000400  06 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000410  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000420  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000430  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000440  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000450  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000460  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000470  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000480  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000490  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000004A0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000004B0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
Your password may be in the OFFSET :0137-0157, and the password is not ASCII code, but the keyboard scan codes. Are you setup the password through BIOS?
PostPosted: August 19th, 2013, 18:36
Thanks guys, for the help with the PM's! Aces, on my PW being 123456, entered it with the lock-screen that comes up. Thanks, again. my buddy is gonna be stoked. :D :D :D
PostPosted: August 23rd, 2013, 10:03
Can someone please help me retrieve my password from my WD My Book Essential.Here's the info i got from its DriveUnlock.
Thanks in advance!
Last login: Fri Aug 16 22:49:28 on console
/Volumes/WD\ Unlocker/DriveUnlock.app/Contents/MacOS/DriveUnlock ; exit;
Johns-iMac:~ JC$ /Volumes/WD\ Unlocker/DriveUnlock.app/Contents/MacOS/DriveUnlock ; exit;
2013-08-23 08:52:43.339 DriveUnlock[5374:903]
volumeParms.vMDeviceID (length = 16)
000c72f5: 64 69 73 6b 32 73 30 73 32 00 55 57 44 4d 79 42 disk2s0s2.UWDMyB2013-08-23 08:52:43.341 DriveUnlock[5374:903]
bsdnameCString (length = 16)
bffff542: 64 69 73 6b 32 73 30 73 32 00 00 00 00 00 00 00 disk2s0s2.......2013-08-23 08:52:43.341 DriveUnlock[5374:903]
bffff542: 64 69 73 6b 32 00 30 73 32 00 00 00 00 00 00 00 disk2.0s2.......2013-08-23 08:52:43.341 DriveUnlock[5374:903] Launch BSD Device Name = disk2
2013-08-23 08:52:43.341 DriveUnlock[5374:903] WD Drive Unlocker launched from device disk2
Found USB My Passport device with a Product ID of 4416 (1140).
IORegistryEntryGetName = IOSCSIPeripheralDeviceType00
IORegistryEntryGetName = IOBlockStorageServices
IORegistryEntryGetName = IOBlockStorageDriver
IORegistryEntryGetName = IOSCSILogicalUnitNub
IORegistryEntryGetName = IOSCSIPeripheralDeviceType05
IORegistryEntryGetName = IOCompactDiscServices
IORegistryEntryGetName = IOCDBlockStorageDriver
IORegistryEntryGetName = WD Virtual CD 1140 Media2013-08-23 08:52:43.368 DriveUnlock[5374:903] USB Device disk2 size 36126720
2013-08-23 08:52:43.368 DriveUnlock[5374:903] SES device found.
SES device found.2013-08-23 08:52:43.369 DriveUnlock[5374:903] Unlocking disk2
2013-08-23 08:52:43.399 DriveUnlock[5374:903] WDUnlockDrive::GetSCSIInquiryData
WDDevice::SendSCSICommand
WDDevice::SendSCSICommand - Using WDDM Interface.2013-08-23 08:52:43.400 DriveUnlock[5374:903] ********* SendSCSICommandUsingWDDM
2013-08-23 08:52:43.401 DriveUnlock[5374:903]
SCSI Inquiry Data (length = 256)
0011e6a0: 0d 00 06 12 5b 00 40 00 57 44 20 20 20 20 20 20 ........WD......
0011e6b0: 53 45 53 20 44 65 76 69 63 65 20 20 20 20 20 20 SES.Device......
0011e6c0: 31 30 31 36 31 31 34 30 57 43 41 5a 41 48 39 37 10161140WCAZAH97
0011e6d0: 37 38 33 32 20 20 20 20 00 00 00 00 00 00 00 00 7832............
0011e6e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0011e6f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0011e700: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0011e710: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0011e720: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0011e730: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0011e740: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0011e750: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0011e760: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0011e770: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0011e780: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0011e790: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................2013-08-23 08:52:43.402 DriveUnlock[5374:903]
WDUnlockDrive::EncryptGetStatus
WDDevice::SendSCSICommand - Using WDDM Interface.2013-08-23 08:52:43.403 DriveUnlock[5374:903] ********* SendSCSICommandUsingWDDM
WDDevice::SendSCSICommand - Using WDDM Interface.2013-08-23 08:52:43.406 DriveUnlock[5374:903] ********* SendSCSICommandUsingWDDM
PostPosted: August 23rd, 2013, 12:54
Anybody? :(
PostPosted: September 17th, 2013, 14:07
Hello
Recently i bought on ebay locked, 3.5 inch, 1TB HDD WD1002faex.
The drive was described as locked, as a result of removing it from LG recorder.
The price was low, so I bid and won (30$).
The drive is in good shape, no SMART Errors and about 2 years of service.
I was trying to remove the password, and once I managed it, by typing in MHDD default WD password WDCWDCWDC...
Then I tried to partition the drive, but after making first partition, parted magic started to see the drive as locked.
Now i know I was moving to fast, without sufficient knowledge.
So the drive went into locked state, but now it is MAX security level and the default master password ins`t working any more.
ZU, MHDD with scripts and hdderase doesn't work too.
There aren't any important data on HDD, I just wish to use It, because it is a fine piece of HDD. (WD black series)
I was trying to run it in safe mode, by jumper all pins 1=2, 3=4, 5=6, 7=8, but then the drive just doesn't start and it's invisible in BIOS.
Can anybody advice me, how to obtain user password from this HDD ?
Users browsing this forum: No registered users and 92 guests
