 Post subject: Seagate Barracuda 7200.11 (HP12 firmware) locked in BSY stat
PostPosted: June 25th, 2013, 4:50
Hi
My Seagate Barracuda 7200.11 hard drive (HP12 firmware) is locked in BSY state.
I read a lot of information about how to unlock Seagate drives (with a Seagate firmware), but it seems that the procedure is different when the firwmare is HP12.
I would appreciate if you could give me the right procedure for the HP12 firmware.
Thanks in advance
Patrick
 Post subject: Re: Seagate Barracuda 7200.11 (HP12 firmware) locked in BSY
PostPosted: June 25th, 2013, 5:37
Maybe this?
viewtopic.php?t=19422&p=178807#p178807
If you have some electronics skill, and if you can build a simple circuit, then I may be able to help you. It should cost you about $5 in parts. Alternatively, I can help adapt something from eBay.
PostPosted: June 25th, 2013, 5:57
I have bought all the necessary material. All I need is information for unlocking a Seagate Barracuda 7200.11 hard disk with HP12 firmware.
Patrick
PostPosted: June 25th, 2013, 6:16
According to that other thread, and assuming that the same method applies in your case, you need to inject an interference signal into the read channel. For that you need a signal generator. Your TTL RS232 adapter is something else entirely. I'm not a data recovery professional, so I don't have personal experience with this problem, but no professional is going to tell you their secret, no matter how trivial. I propose to use a 555 timer, a capacitively coupled probe, and a resistive voltage divider. Some private feedback would suggest that this procedure does indeed work, at least for the ES.2 models.
PostPosted: June 26th, 2013, 4:41
No I didn't try. I want to know the exact procedure before starting. I don't want to damage my hard disk.
Patrick
PostPosted: June 27th, 2013, 13:14
Hi
I've just connected the drive to the terminal, and the message is :
LED:000000CC FAddr:002493D1
Patrick
PostPosted: June 27th, 2013, 17:54
Do you get an "F3>" prompt if you issue "Ctrl-Z" ?
PostPosted: June 27th, 2013, 17:57
I didn't try, since when the disk is in BSY state, the terminal is locked.
PostPosted: June 27th, 2013, 18:14
Why not insulating the head contacts in the first place ?
PostPosted: June 28th, 2013, 0:57
Why is it important to power off/on the disk between the N1 and m0,2,2,0,0,0,0,22 commands ?
Some people say it isn't necessary.
PostPosted: July 8th, 2013, 5:36
Hi
I finally unlocked my hard drive and updated the firmware.
I used the standard procedure, but with the following modifications :
- I used the / and F,,22 commands after the U command
- after the N1 and / commands, powering off and on the drive locked the terminal, so I restarted the whole procedure from the beginning, without disconnecting the drive after the N1 and / commands
I then backed up my data and installed the latest firmware (HP26).
I don't know if it is the simplest procedure or if it works for other people, but it worked for me.
PostPosted: July 27th, 2013, 15:11
The trick to unlock terminal commands on drive with HP firmware:
http://www.overclock.net/t/457286/seaga ... -with-pics
F712 and F,,22 is the trick
:wink:
My firmware database:
PostPosted: July 29th, 2013, 9:19
I didn't use properly the word "unlock" :oops:
What i wanted to mean was if you are stuck in terminal because commands as translator don't work you need to do CONGEN on HP 7200.11 drives.
:wink:
PostPosted: August 21st, 2013, 1:31
what u want to say ? i cannot understand
