 Post subject: ST2000DM001 Errors - Help Needed
PostPosted: July 30th, 2013, 19:32
One of the drives in my NAS just failed and because I was too lazy to set up RAID, I am now in a desperate state of trying to recover data ! Costly lesson this might be. Anyways, I connected a serial terminal with the PCB attached and received the following errors. The drive spins up spits out these errors and just stops responding after that. Here's the dump:
Boot 0x40M
Spin Up
FAIL Servo Op=0100 Resp=0003
ResponseFrame 0880 00FF 06CC 3300 0008 0000 0000 0000 0E8A 0000 0000 0000 0000 0000 0000 0000 4EA5 D8FB A300 46CA 720B 899B F7B9 BCD5 FD3A 1CF9 FFFF 007F 0000 0000 001D 0004 0010
ResponseFrame 0100 0074 06CC 3300 0008 0000 0000 0000 0E8A 0000 0000 0000 0000 0000 0000 0000 4EA5 D8FB A300 46CA 720B 899B F7B9 BCD5 FD3A 1CF9 FFFF 007F 0000 0000 001D 0004 0000
ResponseFrame 0080 0075 06CC 3340 0008 0000 0000 0000 0E7D 0000 0000 0000 0000 0000 0000 0000 4EA5 D8FB A300 46CA 720B 899B F7B9 BCD5 FD3A 1CF9 FFFF 007F 0000 0000 001C 0004 0000
ResponseFrame 0000 0075 06CC 3380 0008 0000 0000 0000 0E6F 0000 0000 0000 0000 0000 0000 0000 4EA5 D8FB A300 46CA 720B 899B F7B9 BCD5 FD3A 1CF9 FFFF 007F 0000 0000 001C 0004 0000
ResponseFrame 0000 0075 06CC 32C0 0008 0000 0000 0000 0E98 0000 0000 0000 0000 0000 0000 0000 4EA5 D8FB A300 46CA 720B 899B F7B9 BCD5 FD3A 1CF9 FFFF 007F 0000 0000 001D 0004 0000
ResponseFrame 0000 0075 06CC 3200 0008 0000 0000 0000 0EC2 0000 0000 0000 0000 0000 0000 0000 4EA5 D8FB A300 46CA 720B 899B F7B9 BCD5 FD3A 1CF9 FFFF 007F 0000 0000 001D 0004 0000
ResponseFrame FFC0 0075 06CC 3280 0008 0000 0000 0000 0EA6 0000 0000 0000 0000 0000 0000 0000 4EA5 D8FB A300 46CA 720B 899B F7B9 BCD5 FD3A 1CF9 FFFF 007F 0000 0000 001D 0004 0000
ResponseFrame FF80 0075 06CC 32C0 0008 0000 0000 0000 0E98 0000 0000 0000 0000 0000 0000 0000 4EA5 D8FB A300 46CA 720B 899B F7B9 BCD5 FD3A 1CF9 FFFF 007F 0000 0000 001D 0004 0000
ResponseFrame FF40 0075 06CC 3280 0008 0000 0000 0000 0EA6 0000 0000 0000 0000 0000 0000 0000 4EA5 D8FB A300 46CA 720B 899B F7B9 BCD5 FD3A 1CF9 FFFF 007F 0000 0000 001D 0004 0000
ResponseFrame FEC0 0076 06CC 3280 0008 0000 0000 0000 0EA6 0000 0000 0000 0000 0000 0000 0000 4EA5 D8FB A300 46CA 720B 899B F7B9 BCD5 FD3A 1CF9 FFFF 007F 0000 0000 001D 0004 0000
Any advice from the gurus out there ?
 Post subject: Re: ST2000DM001 Errors - Help Needed
PostPosted: July 31st, 2013, 1:14
95% game over for DIY.
Complete diagnose needed, not with terminal only.
PostPosted: August 1st, 2013, 9:22
Hi! There was the exact same problem with the hard drive. Tell me, what can it be? Attach 2 files, the sound of the disc and a screenshot of the terminal.
Sound: https://www.dropbox.com/s/ijwen8pbo8fn2ax/audio.mp3
PostPosted: August 1st, 2013, 14:28
Same diagnose.
No DIY solution.
PostPosted: August 2nd, 2013, 17:27
Thanks for the advice.
I am going to give it one last ditch effort as I am not going to spend a large amount of cash on data recovery services. So I am going to ask a couple of newbie questions, so please be patient. I am not adept at understanding HDDs and all their ins and outs but am adept with electronics.
I would like to do a controller board swap as I have another identical hard disk that I purchased around on the same time with the same firmware and has the same build months. I have read online that a firmware transfer is needed. On inspection on the board I found a 25FS406 serial flash memory which I presume holds all of the drive specific information. I can either remove the chip or read it in-circuit and transfer the data contents to a a working controller board.
So before I go through all that effort, I would like to know if it's worth the trouble ? Even if it has a small chance of working I would like to give it a go and would like an expert opinion.
PostPosted: August 2nd, 2013, 19:42
Reasearch the words in the terminal output, especially "servo". It will help you understand better what the problem is related to, as oppose to trying something just to try.
PostPosted: August 2nd, 2013, 20:18
I understand that and agree with what you are saying.
So let me ask a question on that front to help to understand if it's indeed a servo problem on the physical hardware vs. an issue with the driver circuitry on the controller board. If I was to isolate the hard disk using a card stock or completely remove the controller from the hard disk and look at the terminal output, should be expecting different outputs in each of these cases ?
I understand that it would depend on the specific problem the hard disk has, but just wondering what would an expected output from the deep level of experience and understanding of the contributors to this forum.
PostPosted: August 2nd, 2013, 22:27
Your drive is a 2TB. This one here is a 1TB, but basically the same thing, just lower capacity.
viewtopic.php?t=22217&start=
PostPosted: August 2nd, 2013, 23:47
Ok thanks.. Exactly the same symptoms I am seeing.
PostPosted: August 5th, 2013, 4:35
Opened the hard drive, here's the link to the video. Who can tell?
http://www.youtube.com/watch?v=wDH6QQE4 ... e=youtu.be
PostPosted: August 7th, 2013, 6:07
Hi Alex - Yep.. that's exactly what I am seeing on my hard drive as well, although I open mine up in a clean room :) I have kinda given up. Would love to know if there a way to just get some use out of this drive even if all the data is gone.
PostPosted: August 7th, 2013, 6:13
If data is important, what exactly do you think you will achieve by opening it?
PostPosted: August 7th, 2013, 7:13
Then you can make sure it is dead and don't have to wonder anymore ;) Curiosity is a curse for me too, so don't worry, you are not alone
PostPosted: August 7th, 2013, 8:54
Looks like dead heads (maybe accompanied with MD) on both drives
Can be PCB but very unlikely
PostPosted: August 16th, 2013, 4:24
sooo, I'm having exactly the same error... Wanna smack the drive with a hammer :D
Strange thing is that I also had it in the nas server: QNAT, the disk broke maybe 3 days ago...
http://youtu.be/xx6GNejwjn4
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 56 guests
