 Post subject: Re: Problem with my WD15EARS - please help
PostPosted: July 23rd, 2013, 14:36
Cheap indeed!
Good job Dimitris.
Murphy was an optimist
PostPosted: July 23rd, 2013, 15:05
gsiozos wrote:
Good job Dimitris.
:good: :good: :good:
PostPosted: August 13th, 2013, 12:37
northwind, how did you know which PCB(USB) to use? I am having the same problem with my drive right now.
PostPosted: August 20th, 2013, 4:36
the PCB is SATA, not USB. Or I don't understand your question. :(
PostPosted: August 20th, 2013, 4:50
Ah now i read your other thread and figured out that you mean that you need the USB bridge which holds the encryption.
PostPosted: August 20th, 2013, 4:52
I think he wants to know how you knew which bridge board to use.....
(Northwind....back in the room!!!... Hope you had a good break matey.... :D )
East Anglian Data Recovery Services
http://www.eadr.co.uk
"If it's your only copy - then it's not a backup!"
PostPosted: August 21st, 2013, 3:43
Cheers Steve!
