gacpac wrote:
And i answered the other guy like that because i'm asking because i don't know. If i knew about this stuff i would not be asking.
You bought HD Doctor, Data Compass, have experienced other recovery cases but this is the "first case i had this situation" suggesting you have worked on other cases of HDD failure.
How can you expect anyone to believe this is your own drive? Maybe it is and if so I apologize, but for me it seems pretty unlikely...
If you want answers, you need to provide information that is actually relevant:
What were the symptoms originally? Does it passport ok? After you change the heads, does its behavior change? What status registers are displayed? Did you check PCB is native and functional? Can you read NVRAM from the PCB?
Give some relative information and im sure you will get a realistic response. But not from me, you can get the info you need from some other "bi**h"
