 Post subject: Ping but cannot Browse Internet
PostPosted: June 28th, 2013, 7:17
I can ping any site, but any of my browser could not browse any website. I have tried sfc /scannow. As my CD drive is not ok, so I have copied the Win XP files to my C Drive and again try sfc /scannow. Now I can scan most of the windows files, but still some files could not found. Is it necessary to get all DLL files in i386 folder? Is this problem could be solved through sfc /scannow, or have any other issue? Please suggest.
 Post subject: Re: Ping but cannot Browse Internet
PostPosted: June 29th, 2013, 4:53
Are you pinging numeric IP addresses or alphanumeric addresses? If you can reach the former but not the latter, then you may have a DNS problem.
PostPosted: June 29th, 2013, 6:54
This issue should be solved by a complete re-install of Windows XP, and re-install all your software. And I mean "should" as in this is what you should do, as opposed to this might/should fix the problem.
In my experience as a computer administrator of many years, when you start getting problems like this in XP, you might patch up the issue, or remove the malware, but the system is never going to be as good as a complete re-install.
It is not a huge task and your files should not be lost.
I would consider moving to Windows 7, but if you don't want to, a complete re-install is advised.
I agree with both posts above, I would say either you have malware causing DNS issues, or you had malware or malware tried to infect leaving a DNS issue.
The malware around these days is often too entwined in the system to remove totally.
You may be lucky with the software mentioned above, and get connectivity back, but I would be surprised if all issues went away.
PostPosted: June 30th, 2013, 15:19
Before talking about malware, patching, reinstalling etc. , maybe thinking about DNS settings on local PC and on router / resetting the socket layer and checking the TCP/IP stack alone ? 2 minutes... :D
PostPosted: July 1st, 2013, 22:38
I was assuming that if the op was trying sfc, then the reboots and simple stuff was done :)
But yes, start at the simplest things and work up to my suggestions.
Maybe a forum such as whirlpool would be a good place as they deal with internet and broadband issues on a large scale.
PostPosted: July 24th, 2013, 1:30
host file more likely got infected check the following
Windows NT/2000/XP Pro c:\winnt\system32\drivers\etc\hosts.
open with wordpad
in there should only be one ip adress 192.127.000
if there is more on the list then its infected
what your browser your using could be a simple network not automatic set
you can also try this tool to fix the problem with a tcp/ip repair
http://www.majorgeeks.com/files/details ... epair.html
malware or virus will alter the tcp ip information
resetting it should work for you
PostPosted: August 21st, 2013, 2:54
Dear craig6928,
Thanks for your reply. I have check the hosts file. It is like as follows:
# Copyright (c) 1993-1999 Microsoft Corp.
# This is a sample HOSTS filee used by Microsoft TCP/IP for windows.
# This file contains the mappings of IP addresses to host names. Each entry should be kept on an individual line. The IP address should be placed in the first column followed by the corresponding host name
# The IP address and the host name should be se parated by the least one space.
# Additionally, comments (such as these) may be inserted on individual lines or following the machine name denoted by a '#' symbol.
# For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client hosts
127.0.0.1 localhost
PostPosted: August 21st, 2013, 5:05
HOST file is fine.
localhost is your own computer and it is pointing home, 127.0.0.1
Thats why go see the geeky saying sometimes "Theres no place like 127.0.0.1".
BTW, you should not open system files with wordpad (or Write.exe as it is actually) you should use notepad or something like programmers notepad that wont change the format of your file to some arbitrary text file format.
Mate, I think your fingers are faster your brain ;-)
I reckon you are getting confused with home, or localhost 127.0.0.1 , and a regular local LAN address of 192.168.0.x !!
192.127.000 is not valid at all, there are always 4 octets in any IPv4 addy... I will stop short of posting the IPv4 RFC and link to the wikipedia page of TCP/IP ;-)
But anyway, a valid idea to check the file, we know what u meant.
ok, as your issue seems not resolved and I dont care it isnt related to a HDD issue, some ideas:
1) PLEASE PROVIDE MORE DETAIL.... You dont specify the browser, but I am guessing IE8 or 9. If it is IE 6 or 7, please first slap yourself on the back of the head a few times(because I am not close enough else I would do it) then resume ;-)
2) Download another browser such as Chrome or firefox and try them, if it is working fine, it is an IE problem. In this case, go to control panel, uninstall IE and install the latest version you can from Microsoft. If you have to use another computer, then do so. There are also "portable" versions of browsers that run standalone without needing files off your system, and can help get you out of trouble in these cases.
3) scan for malware and viruses (I hate saying "Virii" its like platypuses and platypii..sorry, off on a tangent)
4) Seriously if you dont have a reason to stay on XP, then dont, get windows 7.
5) you dont mention having done anything else the other people have suggested except check the host file. do it and post the results.. They didnt use their time helping to whistle dixie.
6) get a freind that knows about computers come sort it for you, or go to a computer shop or google.
7) Surf your facebook again as one of the above will fix your problem
download another browser,
PostPosted: August 21st, 2013, 15:07
in this situation, making things simple...
use updated superantispyware, make a full scan on o/s installed drive... the prob can be resolved if because of malware.
if somehow u can't update super antispyware, then use another pc to download it's offline updates...
তারপরও যদি প্রবলেম থাকে, নতুন করে এক্সপি ইন্সষ্টল করেন।
if still problem persists, make a fresh installation of winxp
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: August 22nd, 2013, 0:09
Thanks for re-iterating what I already said, glad you agree.......
PostPosted: August 22nd, 2013, 0:48
your host file is ok not infected
but again this does not mean your clean its more likely malware that wont let you get onto any web pages
try and download firefox and see if that lets you surf the net ok
download malwarebyte below
untick the free trail for the pro version
and do a update right away and do a full scan on your machine
www.malwarebytes.org
anti virus wont pickup malware as its a total diffrent engine they use.
as i said we dont know what web browser your using try the following for internet explorer fix
this will reset everything in it.
http://support.microsoft.com/kb/923737
give that a try and report back
PostPosted: August 22nd, 2013, 1:13
Dear HaQue,
Thanks for your suggestion. I have all browser IE, Firefox and Chrome, but none of them are working. Do you think, portable version of browser will work, even the windows have problem? If yes, please suggest where I can get portable browser.
Best regards
Riyad
HaQue wrote:
HOST file is fine.
PostPosted: August 22nd, 2013, 11:26
you dont mention having done anything else the other people have suggested except check the host file. do it and post the results.. They didnt use their time helping to whistle dixie.had similar here, something corrupted.
Indeed.
@riyad202
If there are no other symptoms of virus or malware infection then don't make that a connection issue. Ransomware for instance, actually require the network to function so you can pay them.
It looks like you are ignoring the most fundamental network / DNS instructions suggested above in favour of faulty web browser or possible virus/malware.
This makes me think you don't understand what has been offered as advice.
If that is the case, say so and someone can help you along.
This next section is widely copied and pasted most everywhere: give it a try ?
As you say Ping works try the following for "Connected", if that's no good, then follow the rest of the instructions.
Kern
If status is 'Connected':
Try flushing the DNS:
1. Hit Win-R, type 'cmd' and hit enter (or Start > Run > All programs > Accessories > Command prompt)
2. Type 'ipconfig /flushdns' (without quotes) and hit enter.
3. Check if problem persists. If it does, check the modem/router connection status indicators.
If status is 'Limited or no connectivity'
1. Unplug the network cable, turn off the router/modem.
2. Hit Win-R, type 'cmd' and hit enter (or Start > Run > All programs > Accessories > Command prompt)
3. Type 'ipconfig /release' (without quotes) and hit enter
4. Type 'ipconfig /flushdns' (without quotes) and hit enter.
5. Type 'netsh winsock reset' (without quotes) and hit enter.
6. Type 'netsh int ip reset c:\resetlog.txt' (without quotes) and hit enter
7. Type 'netsh int reset all' (without quotes) and hit enter
8. Type 'netsh routing reset all' (without quotes) and hit enter
9. Type 'netsh routing dump' (without quotes) and hit enter
10. Plug in network cable and turn router/modem back on.
11. Wait 5 minutes.
12. Type 'ipconfig /renew' (without quotes) and hit enter.
13. Check connection status again. It should say 'Connected'.
You may not have to perform all steps, but it covers most reasons that could cause the problem.
If it still doesn't work, try turning off your router/modem AND your computer, wait 20 minutes and then turn everything back on.
Голод не тётка!
PostPosted: August 22nd, 2013, 23:23
remember malware or any type root kits can control the internet connection
and send you to rogue sites and block your pc from the web
if you remove any of these not the correct way they destroy the win socket on the os
if your not getting anywhere else i would say your network card could be faulty or the drivers have crashed
also need to know what type of os your using
go to the below site and download this repair and reset tool for the winsock
http://www.snapfiles.com/get/winsockxpfix.html
PostPosted: August 23rd, 2013, 5:52
Dear HaQue,
I also have tried Portable Firefox, but still not result. Portable Firefox open, but not access any website. No browser like IE, Firefox, Chrome works in my computer, even no software could be updated or activated online.
PostPosted: August 24th, 2013, 3:44
Well, to put it bluntly.. if windows is playing up to this extent, and especially an OS as easy to install and get back up as winxp, I don't fuck around with it. re-install, faster PC, cleaner and mind at easy the bad crap is gone.
Sure you may fix it by fixing the dns, tcp/ip issue etc, but re-install puts mind at ease.
um, you have paid your internet bill and it works, no? this is not as silly as it sounds, I have seen it catch a few ppl out.
PostPosted: September 8th, 2013, 0:17
Have any portable browser available, which can work independently without any necessary windows file? If yes, where I can get it?
PostPosted: September 8th, 2013, 4:15
you are not listening - it is not the browser.
when you can list all the results of the tests digitalferret mentioned then we can continue.
Think of of it like this:
browser needs google.com.
browser asks "windows networking magic" where is google.com
Windows networking magic"asks DNS where is google.com
DNS looks it up and says, oh google.com is at 74.125.237.5
so now it uses tcp/ip to get there.
any of that chain broken, it isn't going to work. there is a lot more to it than that.
re-install windows is all I am going to say now.
full stop
end of story.
Period.
PostPosted: September 8th, 2013, 8:19
HaQue mate, it's been going since end of june? troll surely, or pebkac.
If the only tool you have is a hammer, most everything you see starts to look like a nail.
Maybe try putting it in the freezer ..........
Голод не тётка!
Users browsing this forum: No registered users and 32 guests
