 Post subject: PCB Replacement Question
PostPosted: August 26th, 2013, 18:13
Hello all,
Computer repair tech here looking to get more into the hard drive recovery side of things. I have a spare drive which is faulty (no sound whatsoever when plugged in). From what I read, this is likely a PCB issue.
I am looking for a replacement PCB according to the PCB number (2061-771672-F04). eBay has a few but it looks like they are from slightly different models (mine is a WD5000BEVT).
If I were to purchase a PCB with the same PCB number, but for, say, a WD50005000PVT instead, could I just swap the rom chip? Thank you!
 Post subject: Re: PCB Replacement Question
PostPosted: August 27th, 2013, 3:12
You need to buy a PCB from same drive model, or else from same family if you can identify it.
PostPosted: August 27th, 2013, 3:14
What would qualify as same family?
PostPosted: August 27th, 2013, 3:30
What is the drive full model?
PostPosted: August 27th, 2013, 13:52
WD5000BEVT- 80A0RT0
DCM: HBNTJHB
Date: 14 Apr 2010
PostPosted: August 28th, 2013, 3:25
That one is Mariner family.
PostPosted: August 28th, 2013, 3:47
thank you.
I forget the guys name, but I remember watching a video series that said I should come within about 2 (weeks?) of the date on the drive, and there was something about needing the 5th or 6th correct of the DCM code to be the same. Does that sound right?
PostPosted: August 28th, 2013, 4:05
You may refer to Scoot Moulton.
But in this case what he said does not apply, as he's refering to heads swap on that video.
PostPosted: August 28th, 2013, 14:03
gotcha, thanks! So in this case I would just need the same model pcb and to do a rom chip swap?
PostPosted: August 28th, 2013, 14:10
This supplier will swap U12 for free:
http://www.hdd-parts.com/12102804.html
PostPosted: August 28th, 2013, 14:34
Thanks. They seem a bit pricier than going through eBay, though.
Also, when you say U12, you're talking about the rom chip with 8 legs?
PostPosted: August 28th, 2013, 15:47
Yes.
PostPosted: August 28th, 2013, 16:07
Yes.
Thanks, and sorry about the newbie questions :)
PostPosted: August 28th, 2013, 21:23
In the similar question,
I just happened to get another hard drive (this one is for a customer) that doesn't make any noise when connected, so I assume it also needs a pcb swap.
What do you guys usually search for when trying to find a similar pcb?
the model is wd5000bevt-75A0RT0
and the PCB # is 2061 771672 F04 AA XS AB42 5M56 5 0002060 1062
Can you tell me if this eBay PCB will work for this, as long as I swap the firmware chip?
http://www.ebay.com/itm/WD5000BEVT-22A0 ... 232eb07e33
PostPosted: August 28th, 2013, 21:40
To make sure I'm understanding correctly. Please let me know if this situation works:
I have a WD5000BEVT-24A0RT0 (for example!)
I need to swap the pcb and lets say my pcb is 2061-771672-F04 AA
So I go on ebay and search for 2061-771672-F04.
Let's say I find that PCB but it came from a WD5000BEVT-55A0RTO.
According to http://files.hddguru.com/download/PC-30 ... y/Mariner/
they are from the same family, so as long as I swap the bios chip, I'm ok?
PostPosted: August 28th, 2013, 23:51
Sorry, ignore the first questoin, but I'm just wondering about the second concerning the Mariner family and whether they are compatible
Users browsing this forum: Google [Bot], pepe and 63 guests
