Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
 Post subject: Re: Failed PCB swap?
PostPosted: September 3rd, 2013, 21:05
Measure the voltages between ground and each of the components (with the PCB powered up).
BTW, I believe this will only be a post mortem exercise. :-(
Thanks fzabkar. I think i'll just write this one off as practice and wait for another. I appreciate all your help. If I do choose to check the voltage in the future, what you're saying is I need to plug the board into sata power and then take the voltages down from there, correct? Makes sense
PostPosted: September 4th, 2013, 4:43
Yes. Connect the COMmon probe (black) to circuit ground (eg a screw hole), and the Volts probe (red) to the location being measured.
Users browsing this forum: No registered users and 53 guests
cron
