 Post subject: Western Digital WD30EZRX
PostPosted: September 11th, 2013, 12:29
Due to power surge my hard drive got damage it wont turn
on..then i took to the local hdd recovery they replace Tvs didoes and then hdd
turn.Motor star spinning but it making clicking sound and not detecting on bios.
I replace the u12 ic with identical pcb but same problem.
any solution????
MDL:WD30EZRX-00MMMB0
Western Digital:2060-771698-004 REV-A
Board Number: 2060-771698-004
Main Controller IC: 88i9146-TFJ2
HDD Motor Combo IC: L7251 3.1
 Post subject: Re: Western Digital WD30EZRX
PostPosted: September 11th, 2013, 13:54
Find a new recovery shop.
PostPosted: September 11th, 2013, 13:59
if you care about data stop DIY
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
PostPosted: September 11th, 2013, 15:31
then what is the soultion...its firmware corroputed?
PostPosted: September 11th, 2013, 16:10
will PC3000 help??
PostPosted: September 11th, 2013, 17:52
Clicking sound is most likely a read/write heads damage. If you care about information you have there take it to data recovery company. Otherwise send it to WDC for warranty replacement.
Hard Drives For Sale
Largest hard drive supplier for data recovery purposes
More than 10,000 hard drives in stock and ready to ship
PostPosted: September 11th, 2013, 18:05
If D3 and R67 were damaged, then the most likely culprit is a damaged preamp. That means the drive needs a head swap. Not DIY. :-(
PostPosted: September 12th, 2013, 4:06
any other soultion??
PostPosted: September 12th, 2013, 4:24
Apart from backing up your data before it failed. No.
PostPosted: September 12th, 2013, 7:39
I notice in your original post that you say that the shop replaced the TVS Diodes, but you swapped the U12 to a new PCB....... I really think it would pay you to make sure that the shop actually replaced the TVS diodes and didn't just swap the PCB, and that you in fact had the original PCB back with the original U12 on the drive when you received it back from the shop and before you started to work with it....
http://www.eadr.co.uk
PostPosted: September 12th, 2013, 13:57
Compare the date codes on the PCB and ICs against the date code on the label.
PostPosted: September 14th, 2013, 10:02
local hdd recovery shop replace tvs diodes then it start working but making soft clicking noise and not detecting in bios.The He suggest me to get same identical pcb.
PostPosted: September 14th, 2013, 10:28
Here is the picture of pcb
File comment: Identical PCB
File comment: Original PCB
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 45 guests
