 Post subject: change heads
PostPosted: September 24th, 2013, 2:23
the disk make clicking noise. i changed the heads, it still continues to clicking but its recognize the disk.
after i put the heads back and its the same problem its clicking and recognize but i cannot take the data.
and my donor works well before changing the heads.
my question is if the disk can make problem to the heads?
 Post subject: Re: change heads
PostPosted: September 24th, 2013, 2:53
Either something went wrong during the head swap, or the patient has some platter damage killing the heads.
PostPosted: September 24th, 2013, 7:06
Hello, A better description of the case could give us a better look.
Patient and donor models, the history behind the problem etc etc.
PostPosted: September 27th, 2013, 5:58
hello,
thank you for your answer. the model is WD400BD and the doner is the same and the same dcm. i change the head with the special plastic tools and i used the imager tool.
when i change the head and i don't make any physical damages. when i put the head back to the doner, it can not read any data and the head makes clicking noise.
PostPosted: September 27th, 2013, 6:04
emkanapot wrote:
WD400BD.
I would say alignment problem...at least.
http://www.rescue-it.se
PostPosted: September 27th, 2013, 9:41
mr_spokk wrote:
emkanapot wrote:
WD400BD.
+1
PostPosted: September 27th, 2013, 10:18
Hence my suggestion of media damage or something went wrong :-)
PostPosted: October 1st, 2013, 4:52
hi,
thank you all for your answer.
PostPosted: October 2nd, 2013, 2:17
tnx you
Users browsing this forum: Google [Bot] and 27 guests
