 Post subject: 128 toshiba ssd unlock
PostPosted: September 27th, 2013, 2:58
i have problem with toshiba 128 gb ssd, model THNSNF128GCSS
i need to unlock that drive, i dont need items what are at ssd, because there is new windows only but i need to unlck it to use it. any suggestions?
 Post subject: Re: 128 toshiba ssd unlock
PostPosted: September 27th, 2013, 4:13
If you dont need data, then probably all you need is to make Secure Erase with master password. But you have to find out what master password your model has. Try to cantact to Toshiba technical support, may they will tell you password or advice you service center where you could unlock your drive.
PostPosted: September 27th, 2013, 6:15
this ssd is taken from lenovo t430, and the hard disck manufacture time is october 2012. This lenovo t430 went to motherboard replacement. after that i cant ssd unlock. i will contact toshiba but when somebody has something wise to suggest then i will listen to gladly :)
PostPosted: October 7th, 2013, 9:04
contact with Toshiba technical support didnt help, some other ideas ???
PostPosted: October 10th, 2013, 3:59
what do you mean by didn't help?
they wouldn't tell you the password? They denied knowledge of how to do it? other? Specifics may help others here.
PostPosted: October 10th, 2013, 4:29
SSD sticks to lenovo laptop. If official service will change your motherboard they have to provide you with new SSD, otherwise , unlock the ssd drive also their work due password was set by lenovo hardware.
Angel Data Recovery
PostPosted: October 11th, 2013, 3:02
Contact Joe and ask him if he has a solution for you:
http://www.ja.axxs.net/
AIUI, the passwords are stored in EEPROM. Do you still have the old motherboard?
PostPosted: October 14th, 2013, 3:52
hi,
i contacted to joe and he said that he cant help me :(
no i dont have the old motherbpoard, i had to give old motherboard away when i get new motehboard. But how is motheboard involved with hdd, when the password is stored at hdd eeprom?
PostPosted: October 14th, 2013, 13:48
hi,
Fzabkar meant motherboard's EEPROM.
Angel Data Recovery
PostPosted: October 14th, 2013, 16:10
Yes, I was referring to the motherboard's EEPROM. However, even though "Joe's" site seems to suggest that a HDD password is stored on the motherboard, I don't understand why it should be duplicated there, if indeed it is.
PostPosted: October 15th, 2013, 4:25
Nowadays, actually,no need to keep passwords somewhere. Storing hash is enough to validate the password.
Angel Data Recovery
PostPosted: October 15th, 2013, 18:58
I would experiment with a WD Scorpio drive. Install it in your Lenovo, password protect it, and then retrieve the password using the methods outlined elsewhere in this forum. Perhaps you will be able to see something ...
