 Post subject: hi
PostPosted: October 2nd, 2013, 2:18
hi,
i have one wd 2.5 inch harddisk 500 GB WD5000BEVT, DCM: EBCVJHBB. i connect to power. it spins but make noise. it can not access then i take the lid off. i see the head stick to the platter surface.
i take it out to the parking ramp then put the lid back. i test it again. it Still spins but make noise.
can i use WD 500 GB WD5000BEVT, DCM:HBCVJHBB as doner to change the head?
 Post subject: Re: hi
PostPosted: October 2nd, 2013, 10:08
Ouchhh... Should be compatible.
Hope that data is not important.
Best wishes
PostPosted: October 2nd, 2013, 23:30
hi,
thanks very much.
PostPosted: October 3rd, 2013, 4:34
hi,
i swapped the head with my donor drive. it's still the same. any advice?
PostPosted: October 3rd, 2013, 5:01
pro-service
PostPosted: October 3rd, 2013, 23:30
hi,
is it possible that there is power problem to drive the motor so, finally it stop spinning?
PostPosted: October 4th, 2013, 6:36
There are few things that could make an HDD not spin. It really depends on what is going on. So here is a hint:
An HDD is a device made of several components that are orchestrated to work together to make a drive spin. "Together" testing can throw one off.
The motor is likely not the problem.
PostPosted: October 4th, 2013, 6:50
hi,
thanks for your answer.
Users browsing this forum: No registered users and 264 guests
