 Post subject: WD 3.5" makes some noise pattern
PostPosted: October 9th, 2013, 3:47
hi,
i have WD model: WD5000AAVS-00G9B0 DCM: HHNNHTJMHB size: 500.0 GB. i connect to power. it spins up and makes some noise pattern then stops spinning. i can't access to the drive. what's the problem.
 Post subject: Re: WD 3.5" makes some noise pattern
PostPosted: October 9th, 2013, 4:48
If 'noise pattern' means a short cycle of heads knocking, in conjunction with spindle stopping, very likely you have bad heads
PostPosted: October 9th, 2013, 5:05
hi,
is it possible for bad sectors on platter?
PostPosted: October 9th, 2013, 5:25
possible, but the bad secots would have to be in the system area right where the drives firmwhere is. It's more likely the drive has a head crash. A DR company should give you a free check service I beleave.
Shane
PostPosted: October 9th, 2013, 5:50
emkanapot wrote:
hi,
No - its heads.
PostPosted: October 9th, 2013, 12:01
hddguy wrote:
emkanapot wrote:
hi,
No - its heads.
Agreed.
Users browsing this forum: Google [Bot] and 79 guests
