 Post subject: Seagate User Password Unlock (ST3500312CS)
PostPosted: October 14th, 2013, 14:24
Hi guys,
on this post I'm gonna describe how I did to remove the USER PASSWORD ( no tested ATA PASSWORD yet ) :
1. RS232 to TTL Adapter
I did my own adapter with a little research on the internet here is the results :
The Project
Schematics
The Board Front
The Board Back
RS232 to USB Adapter
2. Preparing the HDD
Removing the board and blocking the contacts
Contacts already blocked
HDD TTL Connections
3. System Ready to be Unlocked
System Running
4. The commands and Procedures
I did a video to show how to proceed -- >> http://www.youtube.com/watch?v=6OFnkTK5coc
Thanks Guys !!
 Post subject: Re: Seagate User Password Unlock (ST3500312CS)
PostPosted: October 15th, 2013, 9:36
Thanks a lot, congrats on the total homebrew Ninja Fu
PostPosted: October 15th, 2013, 9:56
Thanks !! Yeahh It was really home made !!
PostPosted: December 11th, 2013, 2:48
Thanks for posting. I used a serial adapter for NOKIA DKU-5. and i follow your presentation the video. I have successfully unlock the HDD
PostPosted: December 15th, 2013, 19:07
Did someone try this :
http://hdd-tools.com/products/rrs/
or
http://www.hddunlock.com/
Does it really work??????????????????????????????,
PostPosted: December 16th, 2013, 8:36
Good job, but in my opinion use of the command 'm0,2....' is a little dangerous and I would not recommenced this to anyone else wanting to remove ATA lock from such drives...
PostPosted: December 17th, 2013, 17:04
OOOOOOOOOOMMMMMMMGGGGGGG it works!!!!!!!!!!!
I succed the technique with the same hdd.
I take a seagate barracuda 7200.9 (250go) i put a password. Then to unlock put the password just then change the hdd (put the locked) barracuda 7200.11 (500go) then continue the protocol blanck two times try enter............then password changed!!!!!!!!!!!!!!!!!!! ohhhhhh i dont believe it but true!!!!!!!!!!! Now my hdd is unlocked and read in windows wow. I think you have just to find a hdd near the yours (i think better if exactly the same) and do that!!!!!!!!!!!! It saved my life!!!!!!!!!!!!!!!!!!
Ps: excuse my english very bad!!!!!!!!!!! :-)
PostPosted: December 18th, 2013, 2:09
Im not sure but it seems you are happy about it? :_)
good job, congrats.
PostPosted: December 21st, 2013, 11:57
congratulation
http://www.hpwlab.com
PostPosted: January 17th, 2014, 15:15
Why did you think that ??
thanks !!
PostPosted: January 8th, 2016, 7:04
markh0ppus, can you please reupload HDD TTL Connections image?
I have an ST3250310AS hard disk drive and I want to remove the password from the drive in order to use it as an system disk in a computer.
PostPosted: March 3rd, 2016, 7:09
stojke here is the pin out.
File comment: HDD TTL Connections
PostPosted: March 3rd, 2016, 18:30
+1
Title is misleading as this refers to the ATA lock solution (discussed to death on the Internet for half a decade now) and not password removal. It's extremely far from the way I would do it but congrats on getting your data back. Love the homemade ttl adapter. Hope this was your own drive and not a customers.
PostPosted: August 3rd, 2018, 15:20
markh0ppus, Boa Tarde,
Poderia me enviar os esquemas do seu conversor TTL?
PostPosted: August 3rd, 2018, 18:52
It is easier and cheaper to buy one from MercadoLivre .
PostPosted: May 27th, 2021, 17:47
markh0ppus, can you please reupload point 2 images (there should be 2 or 3 images) ?
I have couple of ST3200312CS hard disk drives and I don,t want to waste them.
Users browsing this forum: No registered users and 80 guests
