 Post subject: How important is to look for matching DCM?
PostPosted: October 16th, 2013, 18:51
Hi all,
I heared few differenr opinions about matching the last 4 letters of the DCM between the patient drive and the donor drive while looking for donor drives.
Some say that the DCM is not important and some say that donor matching is based besides model and date also on DCM.
Personally I run through cases that I ordered donors drives which were have the same DCM 4 last letters as the patient but those drives weren't compatible with the patient.
Recently I ordered 2.5 250GB WD drive with the exact 4 DCM letters as the patient but found out that that it has 3 heads while the patient has 4 :/
Best Regards,
 Post subject: Re: How important is to look for matching DCM?
PostPosted: October 17th, 2013, 9:15
Online
DCM cannot tell you number of heads
PostPosted: October 17th, 2013, 9:24
I was searching the forum for that info couldn't actually found something that i can use, is there a way to know how many heads the hdd has?
Data Recovery in the Dominican Republic
https://www.recuperamidata.com/
PostPosted: October 17th, 2013, 9:34
I would have thought one would go with how big the hard drive is, find one with the matching capacity from the same year.
Shane
PostPosted: October 17th, 2013, 9:38
Shane
Thanks Shane so check for the LBA then, so you can get the correct amount of heads, if you cant get a drive close to the date i guess something at least close will do the job.
PostPosted: October 17th, 2013, 10:34
what about areal density? you can have different number of heads for same drive's size.
Bye
Luca
Data Recovery pro in Italy
www.ultrarecovery.com
PostPosted: October 17th, 2013, 10:35
Bye
Luca
Also, same head count but different head map. This is common
PostPosted: October 17th, 2013, 10:48
Bye
Luca
when you think you know something, something new pops up i didn't knew about the areal density, and i never tough the heap map will be needed to do a head replacement. but quick question cant you just edit the head maps? to make the heads work on the drive.
PostPosted: October 17th, 2013, 11:02
Online
if you need H1 and your donor's HSA missing H1 physically, then no matter how you edit the map, you will never be able to read surface 1, unless you move the platter to another physical position (which is not a good thing to do anyway)
PostPosted: October 17th, 2013, 11:29
Oh OK thanks, but lets say you have the exact drive and heads on your donor, i know the head map is different cause each head can read from a different platter, cant i edit the head map there, in that situation?
PostPosted: October 17th, 2013, 11:32
Online
I don't understand your question
PostPosted: October 17th, 2013, 11:38
Sorry OK lets say you have a donor drive with matching heads, everything looks the same but the head map is different on each drive, if you replace the bad heads with the new donor heads cant i edit the head map on the drive i am working, so i can make the head work?
PostPosted: October 17th, 2013, 11:48
Online
Yes you can, but you can only read heads that have the same number on both drives
PostPosted: October 17th, 2013, 11:51
Got it, thank you Doomer
PostPosted: October 17th, 2013, 14:05
We are a little bit out of the subject..
Do you look for matching 4 DCM letters on the patient drive and donor or not?
PostPosted: October 17th, 2013, 15:38
Sometimes I look for 2, but usually not.
http://www.datasaversllc.com
PostPosted: October 17th, 2013, 19:57
What do you look for inorder to find good WD donor drive?
PostPosted: October 19th, 2013, 9:07
It depends upon the model and family, and what you are trying to do (e.g. swap heads, PCBs, make a hot swap donor, etc.). With some drives (esp. earlier ones) DCM is important, but less so with the newer Royal family (seems like I've broken every DCM "rule" with the latter).
There is a lot of conflicting info on the 'net about DCM and much of it is wrong, or else it is "right" some of the time but not always.
PostPosted: October 19th, 2013, 13:23
Does not the areal density dependen on the technology available at the time of manufacturing ? Does not close manufacturing days mean similar areal density ?
Bye
Luca
PostPosted: October 19th, 2013, 17:27
Areal density is not related to DCM. it's a separate topic.
Users browsing this forum: Doomer, Google [Bot] and 283 guests
