 Post subject: WD10EADX with 2060-771640-003 REV A PCB recovery questions
PostPosted: October 22nd, 2013, 17:42
Hello.
I want to recover this disk (WD10EADX with 2060-771640-003 REV A PCB).
I found some spots on PCB, maybe it's corrosion. Photos for more info.
This disk was used in external box and exactly same spots are on USB bus in external box.
My plan is to buy another 2060-771640-003 REV A PCB and try to replace original PCB. I found 1050 number on IC, so that's probably PCB's date of manufacture.
I'm able to switch BIOS IC (U12?) by myself (I have all needed hardware and friend skilled in electronics - soldering).
I want to ask first before I buy some PCB if anyone can help me to decide what happened and if PCB change can help.
Thanks for any ideas.
Josef
 Post subject: Re: WD10EADX with 2060-771640-003 REV A PCB recovery questio
PostPosted: October 22nd, 2013, 17:55
What is the symptom?
The discolouration is oxidisation. You can clean it up by gently rubbing it with a soft white pencil eraser.
FWIW, I can see a "5110" number on the PCB. Probably a WWYY date code, ie week 51 of 2010.
PostPosted: October 22nd, 2013, 17:57
You haven't said what the symptoms of the problem are.
Dead?
Normal spinup?
Stay spinning?
Spin down?
Clicking?
Scraping?
PostPosted: October 22nd, 2013, 17:59
Sorry guys.
After plug into power and sata it starts (spins for a while) and stops. No clicking. I didn't tried this at home I just heard it from friend. I can test it myself, but I'm afraid to do anything to prevent any additional damages.
PostPosted: October 22nd, 2013, 18:01
Bad heads. Not likely PCB
http://www.datasaversllc.com
PostPosted: October 22nd, 2013, 18:49
Do you think I can try it myself to plug it again a maybe record it? I only heard this from my friend. So I'm not sure what's current status.
And in that "bad heads" case is there any chance to recover data in any other way?
PostPosted: October 22nd, 2013, 19:09
I wouldn't continue to operate it in this condition.
Clean room & experience are needed now, IMHO.
PostPosted: October 22nd, 2013, 21:00
OK, thanks a lot jono-ats.
PostPosted: October 23rd, 2013, 2:22
Yes, agree.
Almost certainly physical heads issues. Not DIY I'm afraid.
PostPosted: October 23rd, 2013, 5:10
OK, thanks for your opinions.
What do you recommend me to do now? And how much it will cost approximately? I'm from Europe, Prague.
PostPosted: October 23rd, 2013, 6:45
Don't power on the drive until you find a reputable DR pro near your area ( power on drive at this condition will make things worse ).
Good luck
PostPosted: October 23rd, 2013, 12:39
I want to share end of my story with you guys.
Today I cleaned PCB using wooden pick, microscope and pencil rubber where it was possible. I tried to plug it into PC vie external USB bus.
System found a drive, but didn't find any partition. So I used brilliant SW TestDisk (http://www.cgsecurity.org/wiki/TestDisk - it saved my life many times) to get all my important data from disk (quick search was enough). They were copied successfully. I also let it write actual partition table back to disk and after reconnect it showed in system properly. I'm not going to use that disk anymore, since it is not reliable anymore. But I'm really happy.
Thanks for all your help. Mainly for ideas about PCB changing. You were true. It definitely wasn't case for PCB change.
PostPosted: October 23rd, 2013, 13:39
Nice work!
PostPosted: October 23rd, 2013, 15:00
Great result :-)
PostPosted: October 24th, 2013, 2:53
Thanks guys.
I have results before and after cleaning if someone is interested.
PostPosted: October 24th, 2013, 8:59
Well done. :)
PostPosted: October 24th, 2013, 10:35
@retro, may I use your photo? I have an idea for a FAQ/tutorial.
PostPosted: October 25th, 2013, 0:31
Sure, you can fzabkar. Send me link after you'll do it. I want to read it.
PostPosted: October 25th, 2013, 22:29
Fzabkar, please start a tutorial on PCB cleaning.
Also, please let us know in this thread (give us links) where we can get your other tutorials like testing pcb with multimeter and others. I have lost track of the tutorials.
PostPosted: November 8th, 2013, 5:55
I wouldn't call it a tutorial. It's more like a tech note.
Oxidisation on Western Digital PCBs:
http://malthus.zapto.org/viewtopic.php? ... 1789#p1789
