 Post subject: How about firmware for Seagate ST9500325AS
PostPosted: October 24th, 2013, 10:25
Trying to copy data from a 2.5" hard disk using an external copy tool I heard some electric sparks when connecting the power supply...
Victim:
Seagate Momentus 5400.6 500GB, 2.5"
Model : ST9500325AS
PN: 9HH134-286
Firmware: 0002SDM1
PCB Number: 100536286 RevE
PCB Label: 100536284
And here a link to a shop selling the PCB with good photo's: http://www.onepcbsolution.com/729279968.html
I know I will have to swap the EEPROM chip, marked 25U406B: 8-pin, 512kByte
http://www.datasheetdir.com/LE25FU406BTT+512KB-Flash
I can order this PCB from the USA but because I'm living in Europe I can get it faster and cheaper from a local supplier. It's just that the local supplier is promoting the PCB for a different firmware version and drive capacity (but same PCB number).
I know some drives just store the drive parameters in the EEPROM, but considering the large EEPROM size is it save to assume all the firmware is in this chip?
Do you think I can just order a PCB with exact same PCB number and then swap the EEPROM chip? Even when the PCB originally was for a model with different firmware?
 Post subject: Re: How about firmware for Seagate ST9500325AS
PostPosted: October 24th, 2013, 15:51
You might have just blown one of the Diodes that protect the device from over current. Can we see some images of the PCB board, both sides...
Shane
PostPosted: October 24th, 2013, 16:59
Hi, same "PCB Label: 100536284" should do it.
http://www.rescue-it.se
PostPosted: October 24th, 2013, 17:02
I don't see anything special to the components, except for the large chip closest to the SATA connector, it has a very tiny hole of about 0.2mm (0.01 inch) which makes me think this one got fried. Markings on this chip are almost impossible to read, looks something like 'UP08'.
PostPosted: October 25th, 2013, 8:05
You have PM
PostPosted: October 25th, 2013, 15:00
Thanks everybody. I ordered a replacement PCB which will be delivered in about 10 days.
Users browsing this forum: pepe and 171 guests
