Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2
 Post subject: Re: wdr 3.6 and its functionalities
PostPosted: October 26th, 2013, 10:38
hehehe. yes u r right .
in these videos i work hard. alot of my experience . i have many videos in which u can repair hdd which has head 0 and 1 is damaged but other heads are ok . in this condition u need to perform complete arco and selfscan .
PostPosted: October 26th, 2013, 10:55
However, I ask Mr. Waqas Ali to release the video of Rom regenarartion in replacement PCB freeee.
PostPosted: October 27th, 2013, 1:50
hi
when u get donor hdd or donor pcb
1. find matching firmwares
2. upload rom to patient hdd
3. now hdd gives access to modules, if not then try to find donor firmware with different mirco code. and check it gives access to firmware or not if yes proceed to next step
4. now open module number 11 and see mirco code version after seeing version u need to find rom which has this micro code. if u r unable to find then proceed to next step
5. if hdd pcb is 1640 or greater then upload permenant overlay then open modules directory and write all overlays modules and power reset
6. now hdd gives detection, but have some green block , now connect it to the pc and copy all your data. if no data proceed to next step
7. run reserved area arco and after complete format reserved area
8.now upload 01 module via road map option and initialize it. after that wirte 11 module. and after that close modules directory and open it again now write all modules except 01 and 35.
and do power reset
9. now run full arco
10. now format with p=list
11 the end
note (the overlay which u r writing is same with rom micro code otherwise hdd cannot give detection and before doing this backup all original modules)
Hope u will understand this
thanks
PostPosted: October 27th, 2013, 2:48
Thank you Mr. Ali for distributing a bit of your experience, let us try it and then the thanx giving ceremony will take place in this thread. But the process may seem to be a little bit tougher for newcommers.
Also, we thank "HDDGURU website authority" for starting a STOCK THREAD of all CHINA HDD Software i.e., for WDR, SRT, MRT and the like. But since the sanctity of the uploaded modules cannot be verified under present circumstances may we request HDDGURU website authority to start a new method for confirming ""whether you gave found the modules 100% ok"" type confirmation on each stock modules uploaded. Then only members will get confidence on the stock modules uploaded.
PostPosted: October 27th, 2013, 3:01
i tested most of firmwares in hdd guru ftp . all are ok 100%
PostPosted: October 27th, 2013, 3:05
A+++ certifiaction. Thanks.
PostPosted: October 30th, 2013, 10:58
Any one who have used wdr to make bad hdd to good. please come out with his story.
PostPosted: October 30th, 2013, 12:24
Members are requested to UPLOAD wdr modules in the following location, to enable advantage of the WDR SW
http://files.hddguru.com/download/Firmware for Union Of China Tools/
PostPosted: October 30th, 2013, 19:54
You might have trouble with the link above because of the spaces in the name.
make sure to not just click, but copy the whole link and paste it to the URL Bar, or use:
http://files.hddguru.com/download/Firmware%20for%20Union%20Of%20China%20Tools/
cheers
PostPosted: November 1st, 2013, 22:25
Spildit please upload some WDR modules to HDDGURU stock. Stock is ALMOST EMPTY
PostPosted: November 2nd, 2013, 7:36
I uploaded MODs from a good Mariner drive
My firmware database:
PostPosted: November 2nd, 2013, 9:38
Thanks, Michael for your contribution. Others having mods from good drive please UPLOAD.
PostPosted: November 9th, 2013, 12:25
I appeal to all to upload modules of WD Drives
