 Post subject: Seagate 7200.7 BSY What tha?
PostPosted: November 13th, 2013, 17:09
I have a 7200.7, 160GB drive. Came in with a bad set of heads, and terminal output verified this. Also the customer said the drive had been dropped prior. So I swap the heads. The donor was a spot on match, because they were purchased at the exact same time. The drive sounds 100% perfect. But it stays in a BSY state. Looked at the output in terminal, and everything looks fine. I can get to the prompt, and no errors at all. However, it's still in a BSY state. Any suggestions on this? Feel free to PM if you wish. Thanks.
 Post subject: Re: Seagate 7200.7 BSY What tha?
PostPosted: November 13th, 2013, 17:17
Are you sure no actions are taking place in the background?
PostPosted: November 13th, 2013, 17:34
Like what? Like any other errors?
PostPosted: November 13th, 2013, 21:03
Reallocation action for example.
PostPosted: November 14th, 2013, 3:53
Does the motor sound normal, or slightly more "sluggish" than normal?
PostPosted: November 14th, 2013, 9:43
No, not at all. The whole drive sounds 100% perfect...and it actually sounds like it calibrates. I've had drives where the motor doesn't quite get up to speed, but in those cases the heads wouldn't even engage. I double checked also with the customer about what they meant when the drive "dropped" and they failed to mention, that it wasn't a physical "drop" it was just the drive dropped out of the system, started clicking, and wasn't showing up any longer :roll: Big difference. lol So there's not even issue with the spindle bearing. I've put the original heads into the donor drive, and the donor has the exact same symptoms this one did originally, just clicking. So I'm sure it was the heads, I just don't know why it's just stuck in this state.
PostPosted: November 14th, 2013, 11:30
You say terminal looks normal, can you write it here?
After drive displays output, can you get a prompt with T>?
If it fails to reach DRDY, and there is terminal output, and heads are compatible and functional, there should be some error at terminal to reflect the issue.
Otherwise, if you reach T> there may be another way to reach data, albeit slowly.
PostPosted: November 14th, 2013, 12:48
Here's what I get in Terminal. Looks fine to me.
Interface task reset
4096k x 16 buffer detected
PUMA - 1_Disk    0.08  10-14-04 18:47
Buzz  - Head Mask FFFF - Switch to full int.
              Spin Ready
8.12  10-14-04 19:03
(P)(H)SATA Reset
Not Interface Age!
VALID Cert Disk Code Detected - Revision # .082
Cert Table loaded
T>
PostPosted: November 14th, 2013, 15:08
"Not Interface Age!"
There's your error!
PostPosted: November 14th, 2013, 16:14
viewtopic.php?f=1&t=9917&start=20
PostPosted: November 16th, 2013, 4:33
              Spin Ready
8.12  10-14-04 19:03
(P)(H)SATA Reset
Not Interface Age!
Cert Table loaded
T>
Dear Friend gtd4242
Agree With PCIMAGE
Fix Age And Your Problem Solved.
Yours Friend
Jignesh Pankhania
PostPosted: November 17th, 2013, 0:23
Spildit wrote:
http://malthus.zapto.org/viewtopic.php?f=2&t=299
On level T do N50,,22
Only at age=50 the drive will operate at ATA level.
Awesome. Thanks. I had just read about that. I'll try it Monday.
PostPosted: November 18th, 2013, 11:23
Yep, that did it. All is well. Thanks!
Users browsing this forum: No registered users and 48 guests
