 Post subject: TERMINAL ERROR BUSY
PostPosted: November 14th, 2013, 9:14
Hi to all!
Is hdd ST2000DL003
TERMINAL ERROR Is busy!
Boot 0x40M
Spin Up[0x000246DF]
Trans.
Rst 0x40M
MC Internal LPC Process
Spin Up
RECOVERED Op=0165 Resp=0005
RECOVERED Op=0055 Resp=0005
RECOVERED Op=0065 Resp=0005
RECOVERED Op=0900 Resp=0005
RECOVERED Op=0600 Resp=0005
(P) SATA Reset
MediaPartition:
Host LBA Length Disc LBA Length Start Cyl Head
Media Partition 00000000 0099B268 00000000 0013364D 00000000 00000000
MC 00000000 0098A210 00000000 00131442 00000000 00000000
MSP 009923C0 00000CF8 00132478 0000019F 00000210 00000004
User Partition 0099B268 0013364D 0000021B 00000004
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MC Seg Disc and Cache Nodes: 40134924 40132A34
Seg Write Preamble VBM start: 000011B2 end: 000011D9
Footer - start: 000011DB end: 00001202
Seg Read Preamble VBM - start: 00001204 end: 0000122B
Footer - start: 0000122D end: 00001254
Reconstruction: MCMT Reconstruction Start
Max number of MC segments 22E0
Nonvolatile MCMT sequence number 0000196A
[RSRS] 1098 DiscLba 00091320 RW_RTL FFFFFFFF
RECOVERED Op=0455 Resp=0005
ProcessRWError -Read- at LBA 00091325 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 00091325!
Reconstruction: EXCEPTION: Seg Read Fail: Status = 0000
Continuing after error
ReadFooters (Forward): Segment 1098 StartLBA 00489900 Starting Footer LBA 00489928
SeqNum 0000196B TotalUserBlocks 0000 DiscLba 00091325 RW_RTL FFFFFFFF
Footer Status = 0000 DiscLba 0009132A RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 0009132F RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 00091334 RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 00091339 RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 0009133E RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 00091343 RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 00091348 RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 0009134D RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 00091352 RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 00091357 RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 0009135C RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 00091361 RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 00091366 RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 0009136B RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 00091370 RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 00091375 RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 0009137A RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 0009137F RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 00091384 RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 00091389 RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 0009138E RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 00091393 RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 00091398 RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 0009139D RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 000913A2 RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 000913A7 RW_RTL FFFFFFFF
Reconstruction: EXCEPTION: Segment Overall Sequence Number Mismatch, No Valid Footer 0000196B FFBFFDFB
Reconstruction: ProcessIncompletelyWrittenSegmen
Problem? is SA?
Нет ничего невозможного
 Post subject: Re: TERMINAL ERROR BUSY
PostPosted: November 14th, 2013, 11:30
Probably some relocation processes should be disabled
PostPosted: November 16th, 2013, 4:29
sempre wrote:
Hi to all!
Is hdd ST2000DL003
Boot 0x40M
Spin Up[0x000246DF]
Trans.
Rst 0x40M
Spin Up
(P) SATA Reset
MediaPartition:
MCMainPOR: Start:
Problem? is SA?
Dear Friend
Not SA Problem This Is Slight Defrent Then Reguler 7200.12 but i can fixed it not so hard.
if u want any help contact me on my skypee id : smart.computech
yours friend
jignesh pankhania
PostPosted: November 19th, 2013, 9:24
F3 T>
ATA 15 Cmds
Ts(ms) dT(ms) Op Cnt LBA
0 99999999 00 0000 000000000000
0 0 00 0000 000000000000
RW 32 Cmds
Ts(ms) dT(ms) xT(ms) Type Option Mode St EC Info
4294967295 99999999 0 FF FFFFFFFF FFFFFFFF FF FFFFFFFF
4294967295 0 0 FF FFFFFFFF FFFFFFFF FF FFFFFFFF
9325 9326 0 2F 000000 000000 1 00000080 SPN_UP NORMAL
9352 27 11 34 000000 000000 1 00000080 TCC 1
9364 12 415 02 002241 000000 2 43110081 XFR RD SYS LBA B 0000000246DF L 0000000C BO 000000 BES 00A750A.00A7809.00A750A
9780 416 2825 02 002241 000000 2 43110081 XFR RD SYS LBA B 0000000246DF L 00000001 BO 000000 BES 00A750A.00A7809.00A750A
12605 2825 447 02 002241 000000 2 43110081 XFR RD SYS LBA B 00000005FAFE L 0000000C BO 000000 BES 00A750A.00A7809.00A750A
13052 447 1440 02 002241 000000 0 43110081 XFR RD SYS LBA B 00000005FAFE L 00000001 BO 000000 BES 00A750A.00A7809.00A750A
14492 1440 419 02 002241 000000 2 43110081 XFR RD SYS LBA B 00000005FAFF L 0000000B BO 000000 BES 00A750A.00A7809.00A754A
14911 419 2825 02 002241 000000 2 43110081 XFR RD SYS LBA B 00000005FAFF L 00000001 BO 000000 BES 00A750A.00A7809.00A754A
17747 2836 439 02 002241 000000 2 43110081 XFR RD SYS LBA B 00000002B877 L 00000190 BO 000000 BES 0042363.0048762.0042363
18186 439 2835 02 002241 000000 2 43110081 XFR RD SYS LBA B 00000002B877 L 00000001 BO 000000 BES 0042363.0048762.0042363
21051 2865 427 02 002241 000000 2 43110081 XFR RD SYS LBA B 000000066C96 L 00000190 BO 000000 BES 0042363.0048762.0042363
21479 428 1843 02 002241 000000 0 43110081 XFR RD SYS LBA B 000000066C96 L 00000001 BO 000000 BES 0042363.0048762.0042363
23323 1844 408 02 002241 000000 2 43110081 XFR RD SYS LBA B 000000066C97 L 0000018F BO 000000 BES 0042363.0048762.00423A3
23731 408 2835 02 002241 000000 2 43110081 XFR RD SYS LBA B 000000066C97 L 00000001 BO 000000 BES 0042363.0048762.00423A3
26580 2849 49 02 005041 000000 0 89800094 XFR WR SYS LBA B 00000002FD5D L 00000001 BO 000000 BES 0042063.00420A2.0042063
26779 199 10 02 005041 000000 1 00000080 XFR WR SYS LBA B 000000028FDC L 00000008 BO 000000 BES 0042123.0042322.0042123
26789 10 51 02 005041 000000 0 89800094 XFR WR SYS LBA B 0000000643FB L 00000008 BO 000000 BES 0042123.0042322.0042123
26840 51 439 02 002241 000000 2 43110081 XFR RD SYS LBA B 00000002FD3F L 00000051 BO 000000 BES 00932CA.05FFFFF.00932CA
27280 440 2591 02 002241 000000 0 43110081 XFR RD SYS LBA B 00000002FD3F L 00000001 BO 000000 BES 00932CA.05FFFFF.00932CA
29871 2591 409 02 002241 000000 2 43110081 XFR RD SYS LBA B 00000002FD40 L 00000050 BO 000000 BES 00932CA.05FFFFF.009330A
30280 409 99999999 02 002241 000000 FF FFFFFFFF XFR RD SYS LBA B 00000002FD40 L 00000001 BO 000000 BES 00932CA.05FFFFF.009330A
RECOVERED Op=0155 Resp=0005 PASS
MSP MainPOR:
MSP Init Metadata
Buf Bytes/VBM 00000210 DBA Base 40000000
Metadata size in bytes 0040
Num Segments 0067
Logical Sector Alignment 00000000
MSP Reconstruction
MSP Read ScratchPad Section 0000 DiscLBA 00132497 BlkSize 00000CE0 Num Segments 00000067 DiscLba 00132497 RW_RTL 000F4240
No valid segments found
MSP MSP Main Store Verify Reconstruction Status 10003000
Reconstruction Status 00003000
MSP Init ScratchPad on DiscDiscLBA 00132497 DiscSize 0000019C PhyBlkLBA 009924B8 BlkSize 00000CE0
Write MSP Segment PhyBlkLBA 009924B8 BlkSize 00000CE0 DiscLba 00132497 RW_RTL FFFFFFFF
MSP MainPOR: Complete
MSP MainPOR: Feature Enabled...
ScratchPad restore NOT required
No HOST FIS-ReadyStatusFlags 0002A185
F3 T>y
File Vol FD Location Size Cylinder Hd Sector
0000 000 fc000042 000000029f06 00000001 000283db 00 0001a6
0001 000 fc001043 000000065325 00000001 00029e82 01 0001a6
0002 000 fc002044 0000000aab50 00000001 000295c6 02 000052
0003 000 fc003045 0000000fa787 00000001 00026d02 04 00026b
0004 000 fc004046 0000001547ca 00000001 0002a2ae 05 00025f
0005 000 fc005047 0000001b8c19 00000001 00029f61 01 0001d0
0006 000 fc006048 000000227474 00000001 000275dc 03 0003dd
0007 000 fc007049 0000002a00db 00000001 0002a36d 05 0000a6
0008 000 fc008068 00000032314e 00000001 ffffffff ff 00ffff
0009 000 fc009069 0000003b05cd 00000001 ffffffff ff 00ffff
000a 000 fd00a000 0000000246df 0000000c 000283c5 00 00001f
000b 000 fc00b32c 00000002b5f7 00000280 000283e1 00 0000f7
000c 000 fc00c32d 00000002f70a 00000280 000283f1 00 00030a
000d 000 fc00d203 00000002900f 00000009 000283d7 00 00026f
000e 000 fc00e204 000000029020 00000003 000283d7 00 000280
000f 000 fc00f205 00000002901d 00000002 000283d7 00 00027d
0010 000 fc010206 000000029023 00000002 000283d7 00 000283
0011 000 fc01120c 000000021708 00000181 000283b8 00 000378
0012 000 fc01220d 000000021000 00000708 000283b7 00 000060
0013 000 fc01320e 000000021889 00000708 000283b9 00 000109
0014 000 fc00a000 00000005fafe 0000000c 00029e6c 01 00001f
0015 000 fc00b32c 000000066a16 00000280 00029e88 01 0000f7
0016 000 fc00c32d 00000006ab29 00000280 00029e98 01 00030a
0017 000 fc00d203 00000006442e 00000009 00029e7e 01 00026f
0018 000 fc00e204 00000006443f 00000003 00029e7e 01 000280
0019 000 fc00f205 00000006443c 00000002 00029e7e 01 00027d
001a 000 fc010206 000000064442 00000002 00029e7e 01 000283
001b 000 fc01120c 00000005cb27 00000181 00029e5f 01 000378
001c 000 fc01220d 00000005c41f 00000708 00029e5e 01 000060
001d 000 fc01320e 00000005cca8 00000708 00029e60 01 000109
0000 001 13100201 000040200000 00000390 ffffffff ff 00ffff
0001 001 13101202 000040200390 0000021c ffffffff ff 00ffff
0002 001 13102203 000040265e00 00001200 ffffffff ff 00ffff
0003 001 10103604 000040267000 00000600 ffffffff ff 00ffff
0004 001 fc104206 000040267600 00000400 ffffffff ff 00ffff
0005 001 1710542b 00004020ddc8 00000070 ffffffff ff 00ffff
0006 001 1710642c 00004020de38 00000070 ffffffff ff 00ffff
0007 001 17107021 000000000000 00000000 ffffffff ff 00ffff
0008 001 17108022 000000000000 00000000 ffffffff ff 00ffff
0009 001 17109023 00004020dea8 000000b0 ffffffff ff 00ffff
000a 001 1b10a43d 00004020df58 00000064 ffffffff ff 00ffff
000b 001 1e10b43c 00004020dfc0 00000960 ffffffff ff 00ffff
000c 001 2310c424 00004020e920 0000002c ffffffff ff 00ffff
000d 001 2710d425 00004020e950 00000058 ffffffff ff 00ffff
000e 001 2810e192 000000000000 00000000 ffffffff ff 00ffff
000f 001 2c10f193 000000000000 00000000 ffffffff ff 00ffff
0010 001 30110194 000000000000 00000000 ffffffff ff 00ffff
0011 001 3411112e 00004020e9a8 00000050 ffffffff ff 00ffff
0012 001 fd112117 00004020e9f8 0000001c ffffffff ff 00ffff
0013 001 fd113118 00004020ea18 000001c8 ffffffff ff 00ffff
0014 001 fd114119 00004020ebe0 0000030c ffffffff ff 00ffff
0015 001 fd11511b 00004020eef0 00000030 ffffffff ff 00ffff
0016 001 fd116120 00004020ef20 00000184 ffffffff ff 00ffff
0017 001 fd117121 00004020f0a8 0000045c ffffffff ff 00ffff
0018 001 fd118123 00004020f508 000001a0 ffffffff ff 00ffff
0019 001 fd119126 00004020f6a8 0000008c ffffffff ff 00ffff
001a 001 fc11a127 00004020f738 00000070 ffffffff ff 00ffff
001b 001 fd11b129 00004020f7a8 00000370 ffffffff ff 00ffff
001c 001 0111c08b 00004025fe00 00001400 ffffffff ff 00ffff
001d 001 0511d08c 000040261200 00001400 ffffffff ff 00ffff
001e 001 0911e08d 000040262600 00001400 ffffffff ff 00ffff
001f 001 0d11f48e 000040263a00 00002400 ffffffff ff 00ffff
0020 001 fd12048f 0000402006b0 00004000 ffffffff ff 00ffff
0021 001 fd121490 00004025f080 00000200 ffffffff ff 00ffff
0022 001 fc12220a 0000402005b0 000000fc ffffffff ff 00ffff
0023 001 39123133 00004020fb18 00000200 ffffffff ff 00ffff
0024 001 fd12413b 00004020fd18 00000200 ffffffff ff 00ffff
0025 001 fd125134 00004020ff18 00000400 ffffffff ff 00ffff
0026 001 fc126137 000040210318 00000200 ffffffff ff 00ffff
0027 001 fd127140 000040210518 00000400 ffffffff ff 00ffff
0028 001 fc128144 000040211918 00000200 ffffffff ff 00ffff
0029 001 fc12931c 000080070000 000003c4 ffffffff ff 00ffff
002a 001 fc12a31d 000000000000 00000000 ffffffff ff 00ffff
002b 001 fc12b31e 000000000000 00000000 ffffffff ff 00ffff
002c 001 fc12c31f 000000000000 00000000 ffffffff ff 00ffff
002d 001 fc12d320 000000000000 00000000 ffffffff ff 00ffff
002e 001 fc12e321 000080014040 00000300 ffffffff ff 00ffff
002f 001 fc12f322 000080015d00 000001c0 ffffffff ff 00ffff
0030 001 fc130323 000000000000 00000000 ffffffff ff 00ffff
0031 001 fc131324 0000800d40c0 00000038 ffffffff ff 00ffff
0032 001 fc132325 00004012fe44 000005a0 ffffffff ff 00ffff
0033 001 fc133326 0000401303e4 00000078 ffffffff ff 00ffff
0034 001 fc134327 000040129898 000065ac ffffffff ff 00ffff
0035 001 fc135328 000040129708 00000190 ffffffff ff 00ffff
0036 001 fd13605b 000040243b18 00001d04 ffffffff ff 00ffff
0037 001 fd137064 00004030f000 00004000 ffffffff ff 00ffff
0038 002 3c238000 00000053a850 00001800 ffffffff ff 00ffff
0039 002 42239439 000000313060 00000510 ffffffff ff 00ffff
003a 002 4623a43a 000000313570 00000254 ffffffff ff 00ffff
003b 002 4a23b438 0000003137c8 00000040 ffffffff ff 00ffff
003c 002 4f23c426 000000313808 0000a000 ffffffff ff 00ffff
003d 002 5223d428 00000031f808 00126a00 ffffffff ff 00ffff
003e 002 5723e02b 000000366018 00000070 ffffffff ff 00ffff
003f 002 5b23f02d 00000031f808 00014020 ffffffff ff 00ffff
0040 002 5f24002e 000000333828 00000290 ffffffff ff 00ffff
0041 002 63241030 000000333ab8 0001402c ffffffff ff 00ffff
0042 002 6524202f 000000347ae4 000003c8 ffffffff ff 00ffff
0043 002 6b243033 000000347eac 0001e038 ffffffff ff 00ffff
0044 002 6f244031 0000003660e8 000dffec ffffffff ff 00ffff
0045 002 73245053 000000366008 00000010 ffffffff ff 00ffff
0046 002 fd246081 000000499650 02b669b0 ffffffff ff 00ffff
0047 002 fd247083 000000446e08 00004044 ffffffff ff 00ffff
0048 002 fd248080 000000499650 03b669b0 ffffffff ff 00ffff
0049 002 fc249084 000000180000 04000000 ffffffff ff 00ffff
0000 003 fc300181 000000029eb6 00000050 000283db 00 000156
0001 003 fc301182 0000000652d5 00000050 00029e82 01 000156
0002 003 fc302183 0000000a06f4 00000050 0002959c 02 000156
0003 003 fc303184 0000000dbb13 00000050 0002751e 03 000156
0004 003 fc304185 000000116f32 00000050 00026d76 04 000156
0005 003 fc305186 000000152351 00000050 0002a2a5 05 000156
0006 003 fc306187 00000018d770 00000050 000284fb 00 000156
0007 003 fc307188 0000001c8b8f 00000050 00029fa2 01 000156
0008 003 fc308196 000000203fae 00000050 000296bc 02 000156
0009 003 fc309197 00000023f3cd 00000050 0002763e 03 000156
000a 003 fc30a20f 000000026863 00000001 000283cd 00 000223
000b 003 fc30b210 000000061c82 00000001 00029e74 01 000223
000c 003 fc30c211 00000009d0a1 00000001 0002958e 02 000223
000d 003 fc30d212 0000000d84c0 00000001 00027510 03 000223
000e 003 fc30e213 0000001138df 00000001 00026d68 04 000223
000f 003 fc30f214 00000014ecfe 00000001 0002a297 05 000223
0010 003 fc310215 00000018a11d 00000001 000284ed 00 000223
0011 003 fc311216 0000001c553c 00000001 00029f94 01 000223
0012 003 fc312217 00000020095b 00000001 000296ae 02 000223
0013 003 fc313218 00000023bd7a 00000001 00027630 03 000223
0014 003 fc31430f 000000029fe7 000001b0 000283db 00 000287
0015 003 fc315310 000000065406 000001b0 00029e82 01 000287
0016 003 fc316311 0000000a0825 000001b0 0002959c 02 000287
0017 003 fc317312 0000000dbc44 000001b0 0002751e 03 000287
0018 003 fc318313 000000117063 000001b0 00026d76 04 000287
0019 003 fc319314 000000152482 000001b0 0002a2a5 05 000287
001a 003 fc31a315 00000018d8a1 000001b0 000284fb 00 000287
001b 003 fc31b316 0000001c8cc0 000001b0 00029fa2 01 000287
001c 003 fc31c340 0000002040df 000001b0 000296bc 02 000287
001d 003 fc31d341 00000023f4fe 000001b0 0002763e 03 000287
001e 003 fc31e14f 000000029145 00000060 000283d7 00 0003a5
001f 003 fc31f150 000000064564 00000060 00029e7e 01 0003a5
0020 003 fc320151 00000009f983 00000060 00029598 02 0003a5
0021 003 fc321152 0000000291a5 00000200 000283d8 00 000015
0022 003 fc322153 0000000645c4 00000200 00029e7f 01 000015
0023 003 fc323154 00000009f9e3 00000200 00029599 02 000015
0024 003 fc324155 0000000293a5 00000100 000283d8 00 000215
0025 003 fc325156 0000000647c4 00000100 00029e7f 01 000215
0026 003 fc326157 00000009fbe3 00000100 00029599 02 000215
0027 003 fc327158 0000000294a5 0000001e 000283d8 00 000315
0028 003 fc328159 0000000648c4 0000001e 00029e7f 01 000315
0029 003 fc32915a 00000009fce3 0000001e 00029599 02 000315
002a 003 fc32a173 00000002fa8d 00000040 000283f2 00 00029d
002b 003 fc32b174 00000006aeac 00000040 00029e99 01 00029d
002c 003 fc32c175 0000000a62cb 00000040 000295b3 02 00029d
002d 003 fc32d15b 0000000294c3 000001d2 000283d8 00 000333
002e 003 fc32e15c 0000000648e2 000001d2 00029e7f 01 000333
002f 003 fc32f15d 00000009fd01 000001d2 00029599 02 000333
0030 003 fc33015e 000000029695 00000219 000283d9 00 000115
0031 003 fc33115f 000000064ab4 00000219 00029e80 01 000115
0032 003 fc332160 00000009fed3 00000219 0002959a 02 000115
0033 003 fc333161 0000000298ae 000000e9 000283d9 00 00032e
0034 003 fc334162 000000064ccd 000000e9 00029e80 01 00032e
0035 003 fc335163 0000000a00ec 000000e9 0002959a 02 00032e
0036 003 fc336164 000000029997 000001d2 000283da 00 000027
0037 003 fc337165 000000064db6 000001d2 00029e81 01 000027
0038 003 fc338166 0000000a01d5 000001d2 0002959b 02 000027
0039 003 fc339167 000000029b69 000000e9 000283da 00 0001f9
003a 003 fc33a168 000000064f88 000000e9 00029e81 01 0001f9
003b 003 fc33b169 0000000a03a7 000000e9 0002959b 02 0001f9
003c 003 fc33c16a 000000029c52 00000042 000283da 00 0002e2
003d 003 fc33d16b 000000065071 00000042 00029e81 01 0002e2
003e 003 fc33e16c 0000000a0490 00000042 0002959b 02 0002e2
003f 003 fc33f203 00000002900f 00000009 000283d7 00 00026f
0040 003 fc340342 000000000000 00000800 00028331 00 000000
0041 003 fc341343 000000000800 00001000 00028333 00 000020
0042 003 fc342344 000000001800 00000800 00028337 00 000060
0043 003 fc343318 000000002000 0000ffff 00028339 00 000080
0044 003 fc344345 000000011fff 0000f001 0002837a 00 00008f
0045 003 fc34532b 000000021f91 00001000 000283bb 00 000031
0046 003 fc346317 000000022f91 000000a0 000283bf 00 000071
0047 003 fc34731a 000000023031 000003e8 000283bf 00 000111
0048 003 fc34831b 000000023419 000012c0 000283c0 00 000109
0049 003 fc349204 000000029020 00000003 000283d7 00 000280
004a 003 fc34a205 00000002901d 00000002 000283d7 00 00027d
004b 003 fc34b206 000000029023 00000002 000283d7 00 000283
004c 003 fc34c208 000000026862 00000001 000283cd 00 000222
004d 003 fc34d001 000000026802 00000040 000283cd 00 0001c2
004e 003 fc34e019 0000000246ed 00000010 000283c5 00 00002d
004f 003 fc34f01a 0000000246eb 00000002 000283c5 00 00002b
0050 003 fc35001b 000000024705 000015ce 000283c5 00 000045
0051 003 fc35101c 000000024705 000000ca 000283c5 00 000045
0052 003 fc35201f 00000002472d 000015a6 000283c5 00 00006d
0053 003 fc35301d 000000024705 00000028 000283c5 00 000045
0054 003 fc35401e 00000002472d 000000a2 000283c5 00 00006d
0055 003 fc355020 0000000247cf 00001504 000283c5 00 00010f
0056 003 fc35603f 0000000267ba 00000030 000283cd 00 00017a
0057 003 fc357300 0000000246d9 00000004 000283c5 00 000019
0058 003 fc358028 000000026865 00000935 000283cd 00 000225
0059 003 fc359029 000000026865 00000234 000283cd 00 000225
005a 003 fc35a035 000000027fd0 00000501 000283d3 00 0001f0
005b 003 fc35b036 000000027acf 00000501 000283d2 00 0000df
005c 003 fc35c037 000000027acf 00000a02 000283d2 00 0000df
005d 003 fc35d052 00000002c712 00001401 000283e5 00 000252
005e 003 fc35e061 00000002f98a 00000001 000283f2 00 00019a
005f 003 fc35f301 00000002900e 00000001 000283d7 00 00026e
0060 003 fc360100 000000028ed3 00000080 000283d7 00 000133
0061 003 fc361101 000000028f53 00000080 000283d7 00 0001b3
0062 003 fc362102 00000002a197 00000280 000283dc 00 000047
0063 003 fc363103 00000002ba07 00000180 000283e2 00 000117
0064 003 fc364104 00000002bb87 00000100 000283e2 00 000297
0065 003 fc365105 00000002bc87 00000080 000283e2 00 000397
0066 003 fc366106 00000002bd07 00000080 000283e3 00 000027
0067 003 fc367107 00000002f00a 00000080 000283ef 00 0003ea
0068 003 fc368108 00000002f08a 00000080 000283f0 00 00007a
0069 003 fc369109 00000002f10a 00000280 000283f0 00 0000fa
006a 003 fc36a10a 00000002f38a 00000180 000283f0 00 00037a
006b 003 fc36b10b 00000002f50a 00000100 000283f1 00 00010a
006c 003 fc36c10c 00000002f60a 00000080 000283f1 00 00020a
006d 003 fc36d10d 00000002f68a 00000080 000283f1 00 00028a
006e 003 fc36e110 000000028fd3 00000009 000283d7 00 000233
006f 003 fc36f115 000000028ff6 00000018 000283d7 00 000256
0070 003 fc370116 00000002905d 00000021 000283d7 00 0002bd
0071 003 fc371131 00000002902b 00000021 000283d7 00 00028b
0072 003 fc372132 00000002e514 00000ab4 000283ed 00 0000d4
0073 003 fc373093 000000028fe8 00000009 000283d7 00 000248
0074 003 fc374209 000000029026 00000003 000283d7 00 000286
0075 003 fc375133 00000002fd3f 00000001 000283f3 00 00015f
0076 003 fc376134 00000002fdac 000008cb 000283f3 00 0001cc
0077 003 fc377135 00000002fd41 0000001a 000283f3 00 000161
0078 003 fc378304 00000002907e 00000028 000283d7 00 0002de
0079 003 fc379305 0000000290a6 00000002 000283d7 00 000306
007a 003 fc37a306 0000000290a8 00000064 000283d7 00 000308
007b 003 fc37b307 00000002912c 00000004 000283d7 00 00038c
007c 003 fc37c14e 00000002913d 00000008 000283d7 00 00039d
007d 003 fc37d16d 000000029c94 00000060 000283da 00 000324
007e 003 fc37e16e 000000029cf4 00000142 000283da 00 000384
007f 003 fd37f30a 000000028fdc 00000008 000283d7 00 00023c
0080 003 fc38030e 000000029f08 000000df 000283db 00 0001a8
0081 003 fc3810bf 000000029132 0000000a 000283d7 00 000392
0082 003 fc3820c0 00000002913c 00000001 000283d7 00 00039c
0083 003 fc383137 00000002fd5d 00000001 000283f3 00 00017d
0084 003 fc384138 00000002fd86 00000001 000283f3 00 0001a6
0085 003 fc385171 00000002fa8c 00000001 000283f2 00 00029c
0086 003 fc386177 00000002fd7d 00000009 000283f3 00 00019d
0087 003 fc387178 000000030add 000000ff 000283f6 00 00032d
0088 003 fc388139 00000002face 0000000a 000283f2 00 0002de
0089 003 fc38913a 00000002fd5b 00000002 000283f3 00 00017b
008a 003 fc38a13b 00000002fd7c 00000001 000283f3 00 00019c
008b 003 fc38b13d 00000002fad8 00000001 000283f2 00 0002e8
008c 003 fc38c13e 00000002fad9 00000001 000283f2 00 0002e9
008d 003 fc38d13f 00000002fada 00000200 000283f2 00 0002ea
008e 003 fc38e140 00000002fd5e 00000014 000283f3 00 00017e
008f 003 fc38f141 00000002fcda 00000065 000283f3 00 0000fa
0090 003 fc3901d0 00000002a417 000011e0 000283dc 00 0002c7
0091 003 fc3911d1 00000002be8e 00000884 000283e3 00 0001ae
0092 003 fd392195 00000002b877 00000190 000283e1 00 000377
0093 003 fc393143 00000002fd87 00000001 000283f3 00 0001a7
0094 003 fc3941d2 00000002bd87 00000007 000283e3 00 0000a7
0095 003 fc395144 00000002facd 00000001 000283f2 00 0002dd
0096 003 fc396136 00000002bd8e 00000100 000283e3 00 0000ae
0097 003 fc39713c 00000002efc8 00000042 000283ef 00 0003a8
0098 003 fc39817a 00000002fd3f 00000051 000283f3 00 00015f
0099 003 fc39920b 000000030bdc 00000001 000283f7 00 00003c
009a 003 fc39a309 000000030bde 00000002 000283f7 00 00003e
009b 003 fc39b066 000000030c1c 00000080 000283f7 00 00007c
009c 003 fc39c065 000000030c9c 00000008 000283f7 00 0000fc
009d 003 fc39d219 000000030c16 00000004 000283f7 00 000076
009e 003 fc39e1e0 000000030be0 00000029 000283f7 00 000040
009f 003 fc39f1e1 000000030be0 0000000b 000283f7 00 000040
00a0 003 fc3a01e6 000000030c09 00000007 000283f7 00 000069
00a1 003 fc3a11e3 000000030c14 00000002 000283f7 00 000074
00a2 003 fc3a2180 000000030ca4 00000040 000283f7 00 000104
00a3 003 fc3a30b7 000000030ce4 00000004 000283f7 00 000144
00a4 003 fc3a4308 000000030ce8 00000014 000283f7 00 000148
00a5 003 fc3a530b 000000030d81 00000018 000283f7 00 0001e1
00a6 003 fc3a630c 000000030cfc 00000082 000283f7 00 00015c
00a7 003 fc3a730d 000000030d7e 00000002 000283f7 00 0001de
00a8 003 fc3a817b 00000002fd88 00000008 000283f3 00 0001a8
00a9 003 fc3a9346 000000030d9f 00000274 000283f7 00 0001ff
00aa 003 fc33f203 00000006442e 00000009 00029e7e 01 00026f
00ab 003 fc340342 00000003b41f 00000800 00029dd8 01 000000
00ac 003 fc341343 00000003bc1f 00001000 00029dda 01 000020
00ad 003 fc342344 00000003cc1f 00000800 00029dde 01 000060
00ae 003 fc343318 00000003d41f 0000ffff 00029de0 01 000080
00af 003 fc344345 00000004d41e 0000f001 00029e21 01 00008f
00b0 003 fc34532b 00000005d3b0 00001000 00029e62 01 000031
00b1 003 fc346317 00000005e3b0 000000a0 00029e66 01 000071
00b2 003 fc34731a 00000005e450 000003e8 00029e66 01 000111
00b3 003 fc34831b 00000005e838 000012c0 00029e67 01 000109
00b4 003 fc349204 00000006443f 00000003 00029e7e 01 000280
00b5 003 fc34a205 00000006443c 00000002 00029e7e 01 00027d
00b6 003 fc34b206 000000064442 00000002 00029e7e 01 000283
00b7 003 fc34c208 000000061c81 00000001 00029e74 01 000222
00b8 003 fc34d001 000000061c21 00000040 00029e74 01 0001c2
00b9 003 fc34e019 00000005fb0c 00000010 00029e6c 01 00002d
00ba 003 fc34f01a 00000005fb0a 00000002 00029e6c 01 00002b
00bb 003 fc35001b 00000005fb24 000015ce 00029e6c 01 000045
00bc 003 fc35101c 00000005fb24 000000ca 00029e6c 01 000045
00bd 003 fc35201f 00000005fb4c 000015a6 00029e6c 01 00006d
00be 003 fc35301d 00000005fb24 00000028 00029e6c 01 000045
00bf 003 fc35401e 00000005fb4c 000000a2 00029e6c 01 00006d
00c0 003 fc355020 00000005fbee 00001504 00029e6c 01 00010f
00c1 003 fc35603f 000000061bd9 00000030 00029e74 01 00017a
00c2 003 fc357300 00000005faf8 00000004 00029e6c 01 000019
00c3 003 fc358028 000000061c84 00000935 00029e74 01 000225
00c4 003 fc359029 000000061c84 00000234 00029e74 01 000225
00c5 003 fc35a035 0000000633ef 00000501 00029e7a 01 0001f0
00c6 003 fc35b036 000000062eee 00000501 00029e79 01 0000df
00c7 003 fc35c037 000000062eee 00000a02 00029e79 01 0000df
00c8 003 fc35d052 000000067b31 00001401 00029e8c 01 000252
00c9 003 fc35e061 00000006ada9 00000001 00029e99 01 00019a
00ca 003 fc35f301 00000006442d 00000001 00029e7e 01 00026e
00cb 003 fc360100 0000000642f2 00000080 00029e7e 01 000133
00cc 003 fc361101 000000064372 00000080 00029e7e 01 0001b3
00cd 003 fc362102 0000000655b6 00000280 00029e83 01 000047
00ce 003 fc363103 000000066e26 00000180 00029e89 01 000117
00cf 003 fc364104 000000066fa6 00000100 00029e89 01 000297
00d0 003 fc365105 0000000670a6 00000080 00029e89 01 000397
00d1 003 fc366106 000000067126 00000080 00029e8a 01 000027
00d2 003 fc367107 00000006a429 00000080 00029e96 01 0003ea
00d3 003 fc368108 00000006a4a9 00000080 00029e97 01 00007a
00d4 003 fc369109 00000006a529 00000280 00029e97 01 0000fa
00d5 003 fc36a10a 00000006a7a9 00000180 00029e97 01 00037a
00d6 003 fc36b10b 00000006a929 00000100 00029e98 01 00010a
00d7 003 fc36c10c 00000006aa29 00000080 00029e98 01 00020a
00d8 003 fc36d10d 00000006aaa9 00000080 00029e98 01 00028a
00d9 003 fc36e110 0000000643f2 00000009 00029e7e 01 000233
00da 003 fc36f115 000000064415 00000018 00029e7e 01 000256
00db 003 fc370116 00000006447c 00000021 00029e7e 01 0002bd
00dc 003 fc371131 00000006444a 00000021 00029e7e 01 00028b
00dd 003 fc372132 000000069933 00000ab4 00029e94 01 0000d4
00de 003 fc373093 000000064407 00000009 00029e7e 01 000248
00df 003 fc374209 000000064445 00000003 00029e7e 01 000286
00e0 003 fc375133 00000006b15e 00000001 00029e9a 01 00015f
00e1 003 fc376134 000000060dbf 000008cb 00029e70 01 000320
00e2 003 fc377135 000000060d54 0000001a 00029e70 01 0002b5
00e3 003 fc378304 00000006449d 00000028 00029e7e 01 0002de
00e4 003 fc379305 0000000644c5 00000002 00029e7e 01 000306
00e5 003 fc37a306 0000000644c7 00000064 00029e7e 01 000308
00e6 003 fc37b307 00000006454b 00000004 00029e7e 01 00038c
00e7 003 fc37c14e 00000006455c 00000008 00029e7e 01 00039d
00e8 003 fc37d16d 0000000650b3 00000060 00029e81 01 000324
00e9 003 fc37e16e 000000065113 00000142 00029e81 01 000384
00ea 003 fc37f30a 0000000643fb 00000008 00029e7e 01 00023c
00eb 003 fc38030e 000000065327 000000df 00029e82 01 0001a8
00ec 003 fc3810bf 000000064551 0000000a 00029e7e 01 000392
00ed 003 fc3820c0 00000006455b 00000001 00029e7e 01 00039c
00ee 003 fc383137 000000060d70 00000001 00029e70 01 0002d1
00ef 003 fc384138 00000006b1a5 00000001 00029e9a 01 0001a6
00f0 003 fc385171 00000006aeab 00000001 00029e99 01 00029c
00f1 003 fc386177 00000006b19c 00000009 00029e9a 01 00019d
00f2 003 fc387178 00000006befc 000000ff 00029e9d 01 00032d
00f3 003 fc388139 00000006aeed 0000000a 00029e99 01 0002de
00f4 003 fc38913a 00000006b17a 00000002 00029e9a 01 00017b
00f5 003 fc38a13b 00000006b19b 00000001 00029e9a 01 00019c
00f6 003 fc38b13d 00000006aef7 00000001 00029e99 01 0002e8
00f7 003 fc38c13e 00000006aef8 00000001 00029e99 01 0002e9
00f8 003 fc38d13f 00000006aef9 00000200 00029e99 01 0002ea
00f9 003 fc38e140 00000006b17d 00000014 00029e9a 01 00017e
00fa 003 fc38f141 00000006b0f9 00000065 00029e9a 01 0000fa
00fb 003 fc3901d0 000000065836 000011e0 00029e83 01 0002c7
00fc 003 fc3911d1 0000000672ad 00000884 00029e8a 01 0001ae
00fd 003 fc392195 000000066c96 00000190 00029e88 01 000377
00fe 003 fc393143 00000006b1a6 00000001 00029e9a 01 0001a7
00ff 003 fc3941d2 0000000671a6 00000007 00029e8a 01 0000a7
0100 003 fc395144 00000006aeec 00000001 00029e99 01 0002dd
0101 003 fc396136 0000000671ad 00000100 00029e8a 01 0000ae
0102 003 fc39713c 00000006a3e7 00000042 00029e96 01 0003a8
0103 003 fc39817a 00000006b15e 00000051 00029e9a 01 00015f
0104 003 fc39920b 00000006bffb 00000001 00029e9e 01 00003c
0105 003 fc39a309 00000006bffd 00000002 00029e9e 01 00003e
0106 003 fc39b066 00000006c03b 00000080 00029e9e 01 00007c
0107 003 fc39c065 00000006c0bb 00000008 00029e9e 01 0000fc
0108 003 fc39d219 00000006c035 00000004 00029e9e 01 000076
0109 003 fc39e1e0 00000006bfff 00000029 00029e9e 01 000040
010a 003 fc39f1e1 00000006bfff 0000000b 00029e9e 01 000040
010b 003 fc3a01e6 00000006c028 00000007 00029e9e 01 000069
010c 003 fc3a11e3 00000006c033 00000002 00029e9e 01 000074
010d 003 fc3a2180 00000006c0c3 00000040 00029e9e 01 000104
010e 003 fc3a30b7 00000006c103 00000004 00029e9e 01 000144
010f 003 fc3a4308 00000006c107 00000014 00029e9e 01 000148
0110 003 fc3a530b 00000006c1a0 00000018 00029e9e 01 0001e1
0111 003 fc3a630c 00000006c11b 00000082 00029e9e 01 00015c
0112 003 fc3a730d 00000006c19d 00000002 00029e9e 01 0001de
0113 003 fc3a817b 00000006b1a7 00000008 00029e9a 01 0001a8
0114 003 fc3a9346 00000006c1be 00000274 00029e9e 01 0001ff
0000 004 fc400100 000040180000 00008000 ffffffff ff 00ffff
0001 004 fc401101 000040188000 00008000 ffffffff ff 00ffff
0002 004 fc402102 000040190000 00008000 ffffffff ff 00ffff
0003 004 fc403103 000040198000 00008000 ffffffff ff 00ffff
0004 004 fc404104 0000401a0000 00008000 ffffffff ff 00ffff
0005 004 fc405105 0000401a8000 00008000 ffffffff ff 00ffff
0006 004 fc406106 0000401b0000 00008000 ffffffff ff 00ffff
0007 004 fc407107 0000401b8000 00008000 ffffffff ff 00ffff
0008 004 fc408108 0000401c0000 00008000 ffffffff ff 00ffff
0009 004 fc409109 0000401c8000 00008000 ffffffff ff 00ffff
000a 004 fc40a10a 0000401d0000 00008000 ffffffff ff 00ffff
000b 004 fc40b10b 0000401d8000 00008000 ffffffff ff 00ffff
000c 004 fc40c10c 0000401e0000 00008000 ffffffff ff 00ffff
000d 004 fc40d10d 0000401e8000 00008000 ffffffff ff 00ffff
000e 004 fc40e10e 0000401f0000 00008000 ffffffff ff 00ffff
000f 004 fc40f10f 0000401f8000 00008000 ffffffff ff 00ffff
0010 004 fc410176 0000402046b0 00009018 ffffffff ff 00ffff
0011 004 10411145 00004026d800 00052a00 ffffffff ff 00ffff
0012 004 fd412546 00004026d800 00004000 ffffffff ff 00ffff
0013 004 fd413547 000040271800 00006000 ffffffff ff 00ffff
0014 004 fd414548 000040277800 00008000 ffffffff ff 00ffff
0015 004 fd415549 00004027f800 00000200 ffffffff ff 00ffff
0016 004 fd41654a 00004027fa00 00040000 ffffffff ff 00ffff
0017 004 fd41754b 0000402bfa00 00000200 ffffffff ff 00ffff
0018 004 fc41814c 0000402bfc00 00000600 ffffffff ff 00ffff
0019 004 fc41914d 0000402c0200 00000200 ffffffff ff 00ffff
001a 004 fc41a04a 00004020d6c8 0000015c ffffffff ff 00ffff
001b 004 fd41b05c 00004020d828 00000550 ffffffff ff 00ffff
001c 004 fd41c05d 00004020dd78 00000050 ffffffff ff 00ffff
001d 004 0d41d489 00004025ef80 00000100 ffffffff ff 00ffff
001e 004 0d41e48a 00004025cf80 00002000 ffffffff ff 00ffff
001f 004 0141f4c2 000040267a00 00000600 ffffffff ff 00ffff
0020 004 054204c3 000040268000 00000400 ffffffff ff 00ffff
0021 004 08421093 000040268400 00001200 ffffffff ff 00ffff
0022 004 fc422094 000040269600 00000200 ffffffff ff 00ffff
0023 004 fc423702 00004025f280 00000800 ffffffff ff 00ffff
0024 004 fc424703 00004025fa80 00000210 ffffffff ff 00ffff
0025 004 fc4250bd 00004030ea00 00000600 ffffffff ff 00ffff
0026 004 fd42632e 0000402c0400 00000200 ffffffff ff 00ffff
0027 004 fd42732f 0000402c0600 00000200 ffffffff ff 00ffff
0028 004 fd428330 0000402c0800 00000200 ffffffff ff 00ffff
0029 004 fd429331 0000402c0a00 00000200 ffffffff ff 00ffff
002a 004 fd42a332 0000402c0c00 00000200 ffffffff ff 00ffff
002b 004 fd42b333 0000402c0e00 00000200 ffffffff ff 00ffff
002c 004 fd42c334 0000402c1000 00000200 ffffffff ff 00ffff
002d 004 fd42d335 0000402c1200 00002800 ffffffff ff 00ffff
002e 004 fd42e336 0000402c3a00 00002800 ffffffff ff 00ffff
002f 004 fd42f337 0000402c6200 00002800 ffffffff ff 00ffff
0030 004 fd430338 0000402c8a00 00002800 ffffffff ff 00ffff
0031 004 fd431339 0000402cb200 00009000 ffffffff ff 00ffff
0032 004 fd43233a 0000402d4200 00009000 ffffffff ff 00ffff
0033 004 fd43333b 0000402dd200 00009000 ffffffff ff 00ffff
0034 004 fd43433c 0000402e6200 00009000 ffffffff ff 00ffff
0035 004 fd43533d 0000402ef200 00009000 ffffffff ff 00ffff
0036 004 fd43633e 0000402f8200 0000b400 ffffffff ff 00ffff
0037 004 fd43733f 000040303600 0000b400 ffffffff ff 00ffff
0038 004 1443870a 000040210918 00001000 ffffffff ff 00ffff
0039 004 19439195 000040211b18 00032000 ffffffff ff 00ffff
003a 004 1d43a0c5 000040245a00 00001080 ffffffff ff 00ffff
003b 004 2143b0c6 000040246c90 00001080 ffffffff ff 00ffff
003c 004 2443c348 000040247d40 00005490 ffffffff ff 00ffff
003d 004 2843d349 00004024d1d0 00005490 ffffffff ff 00ffff
003e 004 2c43e34a 000040252660 00005490 ffffffff ff 00ffff
003f 004 3043f34b 000040257af0 00005490 ffffffff ff 00ffff
0040 005 7c540208 000000499650 00000200 ffffffff ff 00ffff
0041 005 3454101b 000000499650 002b9c00 ffffffff ff 00ffff
0042 005 3c54201c 000000499650 00019400 ffffffff ff 00ffff
0043 005 4054301d 000000499650 00005000 ffffffff ff 00ffff
0044 005 4454401e 00000049e650 00014400 ffffffff ff 00ffff
0045 005 48545019 000000499650 00002000 ffffffff ff 00ffff
0046 005 4c54601a 000000446208 00000400 ffffffff ff 00ffff
0047 005 5854703f 000000499650 00006000 ffffffff ff 00ffff
0048 005 64548300 000000446608 00000800 ffffffff ff 00ffff
0049 005 68549001 000000499650 00008000 ffffffff ff 00ffff
004a 005 8054a034 000000499650 00001000 ffffffff ff 00ffff
004b 005 5054b035 00000053a850 000a0200 ffffffff ff 00ffff
004c 005 5454c036 00000049a650 000a0200 ffffffff ff 00ffff
004d 005 fc54d037 00000049a650 00140400 ffffffff ff 00ffff
004e 005 fc54e04f 0000005daa50 00ebebf8 ffffffff ff 00ffff
004f 005 7054f050 0000005daa50 002b4c00 ffffffff ff 00ffff
0050 005 7455001e 0000005daa50 00014400 ffffffff ff 00ffff
0051 005 78551020 0000005eee50 002a0800 ffffffff ff 00ffff
0052 005 4055201d 0000005daa50 00005000 ffffffff ff 00ffff
0053 005 6c553029 00000031f808 00046800 ffffffff ff 00ffff
0054 005 fc554051 0000005daa50 00500400 ffffffff ff 00ffff
0055 005 fc55504b 000000313000 00000060 ffffffff ff 00ffff
0056 005 fc55644c 000000313000 00000020 ffffffff ff 00ffff
0057 005 fc55744d 000000313020 00000020 ffffffff ff 00ffff
0058 005 fc55844e 000000313040 00000020 ffffffff ff 00ffff
0059 005 5c559061 00000031d808 00000200 ffffffff ff 00ffff
005a 005 6055a062 000000000000 00000000 ffffffff ff 00ffff
005b 005 3855b347 00000044ae50 0004e800 ffffffff ff 00ffff
0000 009 02900208 000040043400 00000200 ffffffff ff 00ffff
0001 009 07901001 000040043600 00008000 ffffffff ff 00ffff
0002 009 09902002 000040043600 00000020 ffffffff ff 00ffff
0003 009 fc903004 0000400437d0 000001f0 ffffffff ff 00ffff
0004 009 13904005 0000400437d0 00000010 ffffffff ff 00ffff
0005 009 15905006 0000400437e0 00000154 ffffffff ff 00ffff
0006 009 0f906017 000040043620 000001b0 ffffffff ff 00ffff
0007 009 1990700c 000040046470 00005190 ffffffff ff 00ffff
0008 009 1f908010 0000400439c0 00000fb0 ffffffff ff 00ffff
0009 009 21909011 000040045c90 000007e0 ffffffff ff 00ffff
000a 009 2590a013 000040044970 00000b10 ffffffff ff 00ffff
000b 009 2990b014 000040045480 00000410 ffffffff ff 00ffff
000c 009 2d90c015 000040045890 00000400 ffffffff ff 00ffff
000d 009 3290d018 00000026ac48 00000400 ffffffff ff 00ffff
000e 009 fc90e03e 00000006c000 00014000 ffffffff ff 00ffff
000f 009 fc90f095 000000000000 00000100 ffffffff ff 00ffff
0010 009 fc910096 000000000000 00000100 ffffffff ff 00ffff
0011 00a fca1103f 00000007b000 00001000 ffffffff ff 00ffff
0012 00a fca1232a 000000000000 00080000 ffffffff ff 00ffff
F3 T>
F3 T>V40
Nonresident GList 0 entries returned
Total entries available: 0
PBA Len Flags Phy Cyl Hd PhySctr SFI
F3 T>V4
Reassigned Sectors List
Entries: 0000, Alts: 0000, Removed: 0000, Pending: 0000
Idx LBA PBA LLLCHS of LBA PLPCHS of PBA SFI Hours Msecs Status BBM Mask
Help? is sa?
PostPosted: November 19th, 2013, 10:21
to me, some other 'random' internet fix or something ever worse was applied before. Can you check the entire service area and files ?
PostPosted: November 19th, 2013, 12:46
After much study of the case...Problem Solved!
Thanks all helps!
PostPosted: November 19th, 2013, 15:29
Please tell us how you solved it
Please
Did you disable congen / reallocation ?
PostPosted: November 19th, 2013, 16:23
it is everything but reallocation bug to me...
PostPosted: November 19th, 2013, 16:29
PostPosted: November 19th, 2013, 16:34
Sorry should have said, did you manually rebuild the non resident Glist
or did it magically reappear
PostPosted: December 11th, 2013, 4:13
Can you place the sollution plz.
Thanks all helps!
PostPosted: December 11th, 2013, 8:07
Please
yes!!
PostPosted: December 11th, 2013, 8:08
not magically!
PostPosted: December 11th, 2013, 8:10
Solved short circuit...
is terminal commands...
PM
PostPosted: October 8th, 2015, 0:22
Banned User
You net to do:
in pcb do the photo.
In comand line do:
F3 T>m0,6,3,,,,,22
(is a: REGENERATE TRANSLATOR).
By RecuperoDatos.com
File comment: short circuit in PCB by RecuperoDatos.com
PostPosted: October 8th, 2015, 0:48
Banned User
Hello, :D
I solve this problem as follows:
Short circuto of the PCB as they are in the photo Image
Then in the terminal:
F3 T>m0,6,3,,,,,22
(is a REGENERATE TRANSLATOR).
After Power reset and :lol:
working again!!
So I solve it.
Users browsing this forum: No registered users and 43 guests
