 Post subject: Seagate st1000dl001 busy
PostPosted: September 17th, 2013, 8:41
Just separating out my st1000dl001 busy issue from the other seagate st1000dl002 busy thread
viewtopic.php?f=1&t=26068
For mine
when putting in online mode (^R) in Terminal, was getting
lots of errors shown
(DOS)STE NEED: 0x039A3533 - 0x039A4570
InitiateMarkPendingReallocateRequest for disc_lba: 039A356B!
(DOS) Read Unrecoverable Error
InitiateMarkPendingReallocateRequest for disc_lba: 039A356C!
(DOS) Write Error
(DOS) Write Failure Reallocation started.
(DOS) AutoWriteReallocationEnabled and Reallocation Request Issued. !84320091
(DOS) WriteFailureReallocateLBARequest is executed successfully.
etc etc
Thanks to help from waqas_ali766 and some congen (F commands or rather flag settings) I was able to get the drive to skip reallocation and go ready
and start to extract the still readable sectors
Unfortunately, and not surprisingly, it freezes after copying of approx. 300MB's worth of sectors on average
and have to reset etc to get it ready again
but slowly getting some stuff off
Mainly as a learning excercise
 Post subject: Re: Seagate st1000dl001 busy
PostPosted: September 17th, 2013, 13:58
For mine
(DOS) Write Error
etc etc
Hi Dear Friend xsoliman
Your Case Is Easy If You Now The Correct Diagnosis.
Read Messeges Carefully And Think About All Lines What Its Says U Get The Solution If You Are Pro.
Its Common Problem Of All New F3 Drives I Have Solved Lots Of Cases.
Thank You
Yours Friend
Jignesh Pankhania
PostPosted: September 17th, 2013, 14:27
Although of course its a 2000GB drive, and even though only approx. 600GB is used, that's still 2000 passes at approx. 300MB a time to recover the data ...
Luckily I only really need a few GB and now know where it is (the two MFT runs were extracted ok)
PostPosted: November 21st, 2013, 12:42
Just for info
Adding in link to another 7200.12 issue where drive would go not ready after reading past a certain point
viewtopic.php?f=1&t=24510&hilit=Max+Certify+Rewrite+Retries&start=0
And that was also later experimented on with the 7200.11 Ready fix applied to 7200.12
and had further issues
similar to my later experiments here
viewtopic.php?f=1&t=19275
viewtopic.php?f=1&t=27319
Users browsing this forum: pepe and 241 guests
