 Post subject: Invalid System Disk, Replace the disk, and then press any...
PostPosted: November 25th, 2013, 5:19
I am going to install my new HDD in my desktop. I want to setup windows XP or 7 whatever but in boot screen it says:
Verifying DMI Pool Data ...........
Boot from CD/DVD :
Press any key to boot from CD.....
Invalid System Disk
_
How can I fix it? I have tried by resetting BIOS settings, locating First boot to CD drive etc.
 Post subject: Re: Invalid System Disk, Replace the disk, and then press an
PostPosted: November 25th, 2013, 6:08
It's ok.
Insert boot media and start with OS installation
Before you start check in BIOS if your new drive is visible
PostPosted: November 25th, 2013, 6:18
Hi jerovsek,
Thank you for your reply. I have inserted boot media, trying to installing windows 7 but boot screen says the same thing! :(
I have checked in BIOS, my new drive is visible.
IDE channel 0 Master [ST320DM000-1BD14C]
IDE channel 0 Slave [None]
IDE channel 1 Master [None]
IDE channel 1 Slave [TSSTcorp CDDVDW SH-S]
PostPosted: November 25th, 2013, 6:59
Hi, when it says press any key to boot to CD that's where you have to quickly press a key.
If it doesn't boot, possible that there is something wrong with the cd, if it is a burnt copy.
In BIOS, try changing the IDE mode to legacy... or whatever is in your BIOS (the OTHER option to AHCI)
there are other option in the BIOS to do with booting as well.
such as boot from flash drive enabled/disabled
pxe boot enabled/disabled etc etc
make sure it looks like boot from cd s ok
cheers
