 Post subject: Help identifying this adapter
PostPosted: November 25th, 2013, 5:58
Hi, i purchased some WESTERN DIGITAL 2.5" 500gb ssd drives, but they have very strange connectors at the back..i needed some advice on identifying the connectors, and any information i might need to convert them to standard sata?
Thank in advance :D
 Post subject: Re: Help identifying this adapter
PostPosted: November 25th, 2013, 14:42
Are you sure those are SSD drives? The connector, despite de poor quality of the picture, seem to be a standard mini USB connector, or maybe some sort of Firewire connector. There's no easy DIY way of converting that to SATA, I'm afraid...
PostPosted: November 25th, 2013, 16:24
These don't look like SSD drive to me either, and that's a micro usb2 connector. It's from a WD passport USB chassis.
Assuming the drives do actually work and you don't need the data then you could convert to SATA by transferring the rom chip at U12 to a compatible SATA PCB.
PostPosted: November 26th, 2013, 23:34
They look like the ones from inside a passport case. grab a usb cable and see :)
PostPosted: November 27th, 2013, 9:16
They are 500GB Laptop HDD with extn USB connector.
PostPosted: November 27th, 2013, 21:06
Hi, a first step in this case would have been to google something like:
"W10eas23xxx" "connector"
or
"W10eas23xxx" "specifications"
where "W10eas23xxx" would be YOUR model number
Users browsing this forum: No registered users and 178 guests
