 Post subject: Internal HDD not recognized in BIOS
PostPosted: December 6th, 2013, 12:08
Hello, i want to ask for a solution for my internal HDD.
I just pausing in a middle of a video when i'm leaving my laptop untouched for maybe 15 minutes, but when i got back, the screen has changed to the startup screen.
When i waited for a while, the screen showed "Operating system not found" message and when i checked BIOS, it shows no sign that my HDD is plugged in and the HDD is making sound like this http://vocaroo.com/i/s1NQacB7OQ1c
Please tell me if there is a solution to this because it happened so suddenly and i didnt have any chance at all to backup my important files..
 Post subject: Re: Internal HDD not recognized in BIOS
PostPosted: December 6th, 2013, 16:55
Sounds like heads are stuck to platter.
If data is important then it's not DIY as it requires the drive opening in a cleanroom.
Shouldn't be too expensive at this stage, prior to DIY attempts.
PostPosted: December 6th, 2013, 16:59
viewtopic.php?t=27426&p=188095#p188095
PostPosted: December 6th, 2013, 17:32
http://forum.hddguru.com/viewtopic.php?t=27426&p=188095#p188095
If data is not that important, then sure give DIY a shot, you've nothing to lose.
But it's a "one shot deal".
Only this week we've seen double figures of "unstuck heads" causing irreversible platter damage with slightly bent heads causing microscopic scratches on the platter surface.
Your data = your choice :-)
Users browsing this forum: Phamthanhktv and 84 guests
