Post new topic Reply to topic  [ 155 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8  Next
 Post subject: Re: WD5000BMVV connector
PostPosted: December 13th, 2013, 4:18
Dear Sbb Kbb,
could you describe a little bit more. Is your drive still in enclosure or not? You need data or not?
PostPosted: December 15th, 2013, 12:44
Hi All!
I have a faulty WD Elements 1023 (WD7500KMVV) which shows the following behaviour:
- when plugged into USB, HDD spins up, sounds normal
- LED blinks or lights continously
- Windows Disk Management shows "eggtimer" for 2-3 minutes, nothing happens ...
- After 5-10 minutes, sometimes it is recognized as Drive E, but without file system
- Data Recovery software tell, that all sectors are bad
- When the issues started, I was still able to see the folder structure, but no content (empty)
I tried Linux and Windows, several USB cables etc. -> always the same. When the problems
I am familiar with soldering, but just want to make sure before I do something wrong:
Is this issue likely to be a faulty SATA/USB bridge chip? Could I have any success when removing C13, C18, C31 and C33 and solder a SATA cable to the E71, E72, E73 and E75 points? Or does this sound like a completely different issue to you?
Thank you guys, I really appreciate any help !
Fritz
PostPosted: December 19th, 2013, 4:00
Hello All,
would someone be able to tell if the above error desciption fits to a faulty USB bridge?
I just don't want to damage the HDD even more by desoldering the capacitors, in case you say the USB bridge couldn't be the problem in this case.
Thanks !!
PostPosted: December 19th, 2013, 4:09
No, I wouldn't say the USB board is the culprit at all.
Almost certainly bad sectors on the drive (which the USB bridge doesn't like very much) or a firmware issue with the actual drive.
Shouldn't be too difficult to recover the data (at this stage) for someone with the right tools and knowledge.
Happy to take a look if you wanna ship to UK?
PostPosted: December 19th, 2013, 4:14
Hello Fritz01,
start new topic, it's better.
It could be issue with faulty USB bridge
PostPosted: December 19th, 2013, 4:21
jerovsek wrote:
Hello Fritz01,
I bet it's not!
In fact, if the drive is sent to me for recovery, and it turns out to be the USB bridge I'll do it for free!
PostPosted: December 19th, 2013, 19:16
pcimage wrote:
jerovsek wrote:
Hello Fritz01,
I bet it's not!
hi pcimage,
It's not my HDD, so I'd habe to talk to the owner. Will let you know, thanks!
PostPosted: July 23rd, 2014, 14:48
A simple questions.
If i make the usb to sata bypass and the data is encrypted... can i just format the HDD and use normally???
There is some risk to use with the bypass like overheat or something like that??
PostPosted: September 9th, 2014, 11:36
Hi.
Does anyone know what are the sata connectors and power of this card?
Thanks!
PostPosted: September 9th, 2014, 11:39
I found this but it is without any description.
PostPosted: September 9th, 2014, 17:56
Those appear to be the SATA Tx/Rx differential pairs, plus the +5V and Ground pins. The photo is demonstrating how to convert the drive from USB to SATA.
PostPosted: September 10th, 2014, 3:44
Yes but I would like to know which is the "transmit +", "transmit -", "receive -", "receive +" and ground?
Thanks.
PostPosted: September 10th, 2014, 3:50
Thanks!
put here pics from both PCB sides, please
PostPosted: September 10th, 2014, 4:05
Here you can download pictures with a higher resolution:
http://www.assistenzainformatica.tv/imm ... 1_full.jpg
http://www.assistenzainformatica.tv/imm ... 5_full.jpg
Thanks.
PostPosted: September 10th, 2014, 4:12
Does this help?
http://ep.yimg.com/ca/I/yhst-1443758497 ... 69_3423582
http://ep.yimg.com/ay/yhst-144375849714 ... v-p1-5.gif
Same MCU, different boards. Follow the Tx/Rx pins from the SATA connector to the MCU.
PostPosted: September 10th, 2014, 4:27
Hi mircot80,
Put here pics from your PCB?
fzabkar can help you to find points
sure
PostPosted: September 10th, 2014, 4:28
I have the same WD5000BMVW-11AMCS0 with real time encryption, and I changed my failed pcb a few years ago (need swap U8 and U12). I done sata connection at that time (for nothing), and I can certainly find the right pinout if you want.
PostPosted: September 10th, 2014, 4:56
how can I know if there is real time encryption?
Yes, what are the right pin out?
Thanks.
PostPosted: September 10th, 2014, 5:21
I think with same part number, your drive have also real time encryption. When I connected my drive with sata connection, I couldn't see any files, and it was ok with new pcb (usb 3.0 connection). No doubt on encryption with this drive.
PostPosted: September 10th, 2014, 5:27
Here are the Tx/Rx pins.
Users browsing this forum: No registered users and 288 guests
