 Post subject: wd10tmvw - 11zsms4 to sata
PostPosted: August 28th, 2013, 1:14
Hey guys
I have replaced the USB to SATA
I know there can solder the PCB card to SATA connection
but i dont remember how
i remember E71 E72 E73 E75 to sata
and i dont know where the power
 Post subject: Re: wd10tmvw - 11zsms4 to sata
PostPosted: August 28th, 2013, 1:46
I see this
source: viewtopic.php?t=25706&f=1&start=0#p174811
PostPosted: August 28th, 2013, 1:48
[url="http://jpg.co.il/view/521d8db1e20e1.jpg/"]Image[/url]
PostPosted: August 28th, 2013, 2:25
yes but cannot see the picture
and its not the same
PostPosted: August 28th, 2013, 3:13
You can power via USB.
See this image I found here. The site does not seem to have problems loading
If you can try a search multimeter continuity. A tip on pin usb positive or negative and the other end into the pcb somewhere you suspect. With the HDD without voltage.
Do it at your own risk
PostPosted: August 29th, 2013, 5:12
tnx i use this
PostPosted: August 29th, 2013, 5:21
Why not just use 771692 PCB?
PostPosted: August 29th, 2013, 13:08
oferav12 wrote:
tnx i use this
This http://utils.ruggero.ws/WD10TMVW/sata-bypass-01.jpg ??
What say change to a native sata pcb? is it possible?
PostPosted: August 29th, 2013, 18:24
Thedemon007 wrote:
oferav12 wrote:
tnx i use this
Yes, but you need to transfer the contents of the ROM.
PostPosted: December 16th, 2013, 5:31
Hello, I have an external hdd http://www.donordrives.com/western-digi ... drive.html (2060-771761-001)and do not know how, stopped working. He tries to run, but after about minute stops. In managing the disk is seen as uninitialized, any attempt results in an error I / 0 I'd like some advice on the recovery disk or data recovery. thank you
(I have Windows7 x64) on XP behaves the same.
I'm scared to try this tutorial, I drive a lot of data.
Please help, thank you.
Users browsing this forum: Google [Bot] and 78 guests
