 Post subject: Anyone have firmware for Hitachi - 5K500.B-500
PostPosted: November 30th, 2012, 3:12
Hi Guys,
Anyone have firmware copy for Hitachi hdd. The HDD details is:
Model: 5K500.B-500 HTS545050B9A300
 Post subject: Re: Anyone have firmware for Hitachi - 5K500.B-500
PostPosted: November 30th, 2012, 3:42
ganapathy05 wrote:
Hi Guys,
And what do you propose doing with said "firmware"?
1. What tool did you use to diagnose the firmware is bad?
2. What is actual symptom of problem?
I assume you are trying to DIY judging by the vagueness of the request. :-)
PostPosted: December 18th, 2013, 0:14
im looking for this firmware aswell i have one that when i got it only showed 31.8gb unallocated and thats it wondering if i flash it if it would work or not
PostPosted: December 18th, 2013, 7:22
I doubt it's a FW issue.
Is it seen as correct capacity in BIOS?
PostPosted: December 19th, 2013, 0:34
no flash will help you
its more likely one of the headstack has failed
like pc image says if you see the correct capacity in the bios
then something else then firmware issues
PostPosted: December 19th, 2013, 4:12
To be honest I suspect it's just logical issues.
If it's seen as full model and capacity in BIOS, then I suspect that's the case and is DIY'able.
Users browsing this forum: No registered users and 97 guests
