 Post subject: st500dm002 no detect
PostPosted: December 20th, 2013, 23:28
My Hard Disk Is :
ST500DM002
Firmware : KC44
IN The Bios Is identified , In Windows No Detected !!!!!
After Connect By TX And RX Controller Reply This Error :
Boot 0x10M
Spin Up[0x00000000][0x0000B67C][0x0000BA10]
Trans.
Rst 0x10M
MC Internal LPC Process
Spin Up
(P) SATA Reset
help pelease!
 Post subject: Re: st500dm002 no detect
PostPosted: December 21st, 2013, 11:11
Is this your drive? If yes, then you perhaps know what has been happening with the drive.. any noticeable change in the drive's behavior prior to no longer working properly?
Have you attempted to enter in diagnostic mode?
PostPosted: December 21st, 2013, 11:18
Does "Partition Find and Mount" detect the drive? I have had a surprising run of results using this software including a Seagate drive which I personally almost botched up through the terminal, and was barely working in windows, and a Sandisk microSD that wasn't working in windows, apart from being detected.
Users browsing this forum: No registered users and 203 guests
