Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
 Post subject: Re: Need firmware for WD15EADS-22P8B0
PostPosted: December 19th, 2013, 10:59
If anyone else besides colleague splidit could be treated with this drive!? If this is not no problem :)
PostPosted: December 22nd, 2013, 10:33
Hey, Spildit. I think I know where the devil is, and so the problem probably is not BAD sectors in SA, the problem is in the ROM, because why I drew, because the system rom how the soldered it W25X020, and the original original, which was a PM25LD020, which is vaguely different than W25X020 , If it were indeed Bad sectors in SA, or a problem with the heads, it would be difficult to have access to the BIOS level, or drive by trapping heads. Here it is not, I think after the new year, how do I get PM25LD020 (primary IC ROM), this reading of the modules will be enabled.
PostPosted: December 28th, 2013, 11:16
Hey everyone.
I apologize in advance that this post under the post, but ran out of time to edit the previous one. So yes, I attach files from the action on the disk. In the file. zip are two folders in the folder where the files are located Work1_old of the previous attempts of the IC PM25LD020, while work1 folder contains the files of the current sample with the IC W25X020. Regards!
:arrow: If my English is not understandable, please write. I recall my English is based mostly on the basis of google translator. Because, I come from Poland.
WD15EADS-22p8b0.part03.rar [2.33 MiB]
Downloaded 556 times
WD15EADS-22p8b0.part02.rar [5 MiB]
Downloaded 584 times
WD15EADS-22p8b0.part01.rar [5 MiB]
Downloaded 570 times
PostPosted: December 31st, 2013, 11:11
If anyone has anything to add to this topic, the invite :)
Btw: Continuing this thread is at this link: http://malthus.zapto.org/viewtopic.php? ... 1&start=20
PostPosted: January 19th, 2014, 8:46
Hello Spildit, If you have the time and inclination to play the HDD, I'm waiting for you with open arms, and I'm almost always online. It's no problem. :)
PostPosted: December 10th, 2014, 19:14
2524884@plugin.gg.aqq.eu_20141208_1_d46e472e0001e8b8.jpg [ 122.18 KiB | Viewed 8667 times ]
HDD Is working fine after 1.5 years fighting with the repair, Attach SMART.
