 Post subject: 3TB's Partitioned As NTFS With MBR Out There?
PostPosted: December 22nd, 2013, 7:55
Guys,
Windows 7 Pro SP1 64-Bit with an ASRock P67 PRO3 (B3) MoBo
that has a UEFI BIOS, i5-2500K and Corsair Vengeance 16 Gigs.
My C, D and E partitions are on a 120 GB NTFS SSD with a MBR.
My present STORAGE HDD is a 2TB Toshiba with a MBR.
I recently purchased a Toshiba PH3300U-1I72 3TB to replace the 2TB.
I always Ghost with DOS Bootable CDs I make with custom
Autoexec.bat files I write, never Windows.
I found out from Symantec that Ghost has issues with GPT.
I found a way to make my 3TB FULLY accessible and set as MBR.
It's Acronis True Image, aka Seagates DiskWizard aka WD's version
of DiskWizard. It puts an "Extended Capacity Manager" in the boot
sector so you get one 2.1TB and one 700+GB partition, BOTH MBR.
See: Seagate DiscWizard CloneDisc for drives larger than 3TB_Part-2
https://www.youtube.com/watch?v=TCLGfj1LSmI
The reason that I'm posting this is to get feedback from anyone who
has used these programs to see if the 3TBers work as any other HDD
would or are there any quirks that have come up since partitioning
your 3TB?
Please post to me.
Thanks in advance for your help.
Big Al
 Post subject: Re: 3TB's Partitioned As NTFS With MBR Out There?
PostPosted: December 22nd, 2013, 21:58
Guys,
I just found this and would like some input before opening the
Toshiba 3TB's box:
Make SURE the 3TB is EMPTY as this will wipe ALL data on the drive
To make a fully accessible 3TB with 4k sector:
1. Boot to desktop.
2. Open "My Computer" in Windows Explorer.
3. Click on the EMPTY 3TB HDD.
4. If the factory made some partitions on it, delete them all.
5. Once it is just one disk, right-click it and click "Format"
6. Select "4096", "NTFS" and "Format".
7. Click OK. Since the 3TB is EMPTY, it should be real quick.
8. It's now ready to be partitioned to your liking up to 2.7 or so
TB's total and is set as MBR.
So, has anyone used these programs or the "4096", "NTFS" and
"Format" method???
PostPosted: December 22nd, 2013, 22:54
Just a note...
The formatting has nothing to do with what is on the disk. It can be full or empty and would take the same amount of time. The reason it is quick is because "Quick format" is selected. Uncheck that box and it will take a LOT longer regardless of empty, half-full or full
PostPosted: December 23rd, 2013, 11:07
The 2nd post above
is only applicable if it is a DATA disk (not a boot disk)
and if it if being accessed through an interface (usually USB) that presents it as a 4K sector drive
Can then set it up as an MBR drive
If using a 512byte interface eg SATA
will still be limited to a max 2TB partition if MBR
and will need to use GPT if want >2TB
PostPosted: December 23rd, 2013, 16:06
I may be wrong but I think that if the operating system and BIOS do recognize 4k sector size, it is possible to have MBR formatted disk up to 14 TeraByte.
Big_Al_C wrote:
Guys,
Toshiba 3TB's box:
1. Boot to desktop.
"Format" method???
PostPosted: January 4th, 2014, 22:29
Sorry to say that I've heard from numerous people with 3+ TB's
and they have grave reservations about Acronis/Seagate/WD's
Extended Capacity Manager to get full MBR 3TB HDD's and they
say that the "4096", "NTFS" and "Format" won't work.
Well, I HATE to admit defeat, but since I CANNOT find the
Ghost v11.5.1.2298 from GSS 2.5.1 that DOES see GPT HDD's,
I've concluded that my only recourse is to relegate my 3TB to
GPT and to BACKUP status to my 2TB Toshiba and dusted-off 1TB
Hitachi MBR HDD's that I'll be using as my main drives.
After numerous E-Mails to a bunch of Cloning Software companies,
I've settled on MiniTool Partition Wizard v8.1.1 from
http://www.partitionwizard.com (To top it off, it's FREE!!!)
to pre-partition my 3TBer and to do the "Copy partitions from
my 1 and 2TB MBR's to partitions on my 3TB GPT" and use my
Ghost v11.5.1.2269's Make and Restore Bootable CD's to do my
MBR C and D Drive imaging chores.
It's been fun--NOT!
Big Al
Users browsing this forum: Google [Bot] and 239 guests
