Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
 Post subject: Re: Seagate 500GB ST3500830ACE
PostPosted: December 27th, 2013, 19:54
Spildit wrote:
By the way - CTRL+R will "Load Cert" so you will not get those "No VALID Cert Code Detected" errors when trying those commands.
:mrgreen:
I already found those codes while playing around hehe...
Thanks ;)
Shane
PostPosted: December 28th, 2013, 16:30
Okay, new problem that has me stumped. I decided to load my computer in windows XP to format the drive and partition using the software that works for XP to get more information, but when I open the Putty terminal the drive results are not in English. I get this "fæøfx`f`àøø`fxffæ~àfx`fàffæøææ````æfx```xf~fxfþfàæ~þæfþþ`þ" when it should be:
Reset
4096k x 16 DRAM
GALAXY - 1_Disk S-6D 09-22-06_15:48
Buzz HM SFI
So I decided to load up WinME where it worked fine before, but now that too is messed up. I only get "fæøfx`f`àøø`fxffæ~àfx`fàffæøææ````æfx```xf~fxfþfàæ~þæfþþ`þ" when I turn on the drive. HELP!
Shane
PostPosted: December 28th, 2013, 17:30
Strange, changing the data rate to 4800 did the trick. Not sure whats going on there. Anyway back to the drive. I ran PCCheck on the drive, did a mechanics stress test and that was fine. When I did a destructive write test, putty displayed errors as listed below.
Reset
4096k x 16 DRAM
Buzz HM SFI
(P)PATA Reset
Master
(S)Master
(S)Master
Master
Master
Failure of 0025901f can't be fixed
Failure of 00259020 can't be fixed
Failure of 00259021 can't be fixed
Failure of 00259022 can't be fixed
Failure of 00259023 can't be fixed
Failure of 00259024 can't be fixed
Failure of 00259025 can't be fixed
Failure of 00259026 can't be fixed
Failure of 00259027 can't be fixed
Failure of 00259028 can't be fixed
Failure of 00259029 can't be fixed
Failure of 0025902a can't be fixed
Failure of 0025902b can't be fixed
Failure of 0025902c can't be fixed
Failure of 0025902d can't be fixed
Failure of 0025902e can't be fixed
Failure of 0025902f can't be fixed
Failure of 00259030 can't be fixed
Failure of 00259031 can't be fixed
Failure of 00259032 can't be fixed
Failure of 00259033 can't be fixed
Failure of 00259034 can't be fixed
Failure of 00259035 can't be fixed
Failure of 00259036 can't be fixed
Failure of 00259037 can't be fixed
Failure of 00259038 can't be fixed
Failure of 00259039 can't be fixed
Failure of 0025903a can't be fixed
Failure of 0090b3ef can't be fixed
Failure of 005dada7 can't be fixed
Failure of 005dada8 can't be fixed
Failure of 005dadc4 can't be fixed
(Drive seemed to crash from there. Might be the USB interface)
Reset
4096k x 16 DRAM
HM SFI
(P)PATA Reset
Once question I do have, could a dripped pin on the IDE cable cause this to happen?
PostPosted: December 28th, 2013, 19:48
Okay, update for all, Now I am really messing with the drive. tried to activate the N4,22 command but nothing happened. Somewhere in the process I messed up the Age of the drive. Made it go to age 4 by mistake, that gave an error on bootup. Not sure how important that was.
Anyway, got it back to Age 50 by using the command N50,,22 so the drive looks normal from terminal. Now preforming another test from this forum http://malthus.zapto.org/viewtopic.php?f=2&t=299.
Started the test and now the drive is doing a lot of strange stuff.. Lots of writing on terminal and such...
Update,
For some reason, N4,,22 dumps the drive into Age 04 and does nothing... Well no display on the screen.
I am staying well away from N2 commands.
Shane
PostPosted: December 28th, 2013, 20:27
Well, for some reason I can't edit my posts... Umm, anyway, the test I am doing is a N10,,22, I believe I need to run N50,,22 to get the drive back to age 50 to run normally again... Slowly learning...
PostPosted: December 29th, 2013, 18:38
That Self Scan did not work very well, but more of my programs are able to reconise the drive now. But when I attempt to partition the drive for use, the drive constantly clicks with bad clusters and locks up my system. Any commands I can use on the drive terminal that will scan the drive and add them to the P-List, or some way to move the partition sector away from the damage part of the drive?
Any help would be welcomed.
Shane
PostPosted: December 30th, 2013, 14:49
I have attached a log of a level 3 self scan which I hope will put the bad sectors and stuff in the P list as stated on the website somewhere above the post. If anyone can pinpoint the problem, I am all ears. I will test the drive later when my kids have finished watching cartoons of my server.
putty.txt [1.25 MiB]
Downloaded 812 times
PostPosted: December 30th, 2013, 15:39
So, managed to make some progress. Whatever self scan level 3 did the drive can now format and partition, but as expected there seems to be bad sectors lurking around. If the bad sectors are on one platter, or perhaps a weak head. Is there any way to find out which platter or head is bad?
I think I have found a way to download Modules using putty commands, will mess around with that later and perhaps backup the files needed to do a level 2 scan.
Also after more tests it does seem like removing a platter or head might work if the damage is limited to one platter.
Shane
Users browsing this forum: No registered users and 76 guests
