 Post subject: Seagate 1TB External HD, beeping & not recognised
PostPosted: December 30th, 2013, 19:05
Hey guys,
As you can see in the title I have a Seagate 1TB external hard drive; model number SRD00F1.
Just this evening i was trying to put some photos on to it and it wasn't loading in to the hard drive. So i restarted my laptop, and it wasn't showing up. I disconnected and reconnected the hard drive and it started beeping, the computer made the noise they make when connecting a USB device and then made the noise when disconnecting a USB device, and then the light started flashing. From my reading on the internet and on Seagates website the flashing indicated an error with the drive. Any suggestions on what i can do? I understand that the warranty doesn't ensure data recovery, just a replacement drive, which isn't really much good to me as what i am bummed about is the loss of thousands of photos.
Any suggests on what i can do?
Oh, it is powered via the USB port, i have tried multiple ports and also another laptop...none of which made any difference.
Cheers,
James
 Post subject: Re: Seagate 1TB External HD, beeping & not recognised
PostPosted: December 30th, 2013, 19:31
Can you provide a recording of the drive and also, try and see if the drive cable can connect to two ports. The drive might need more power. Otherwise try it on a desk top computer.
If it still does not work then you might have a crashed disk. But we need to listen to the sounds it makes.
Shane
PostPosted: December 30th, 2013, 19:51
In the morning I will make a recording and put it on YouTube. I shall also try it on a desktop tomorrow. The Usb can only connect to 1 port.
PostPosted: December 31st, 2013, 10:51
This is a video of the sound it makes. It is REALLY REALLY quiet, but it is as good as i could get. Tried recording it many times.
http://www.youtube.com/watch?v=j5eBwbGN ... e=youtu.be
PostPosted: December 31st, 2013, 12:01
That sound at the beginning does sound like the drive is trying to spin up, but I can't be sure. Can you hear the drive spin up at all. when plugged in and also did you try it on another computer to resolve my other question about lack of power.?
Users browsing this forum: No registered users and 302 guests
