Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2
 Post subject: Re: Samsung HM160JI
PostPosted: January 11th, 2014, 17:26
Maybe try "SB FF" or "SB FE" ???
Have you tried the "PK" command? Would this have anything to do with autoparking ???
Please don't blame me if you break anything. :-)
PostPosted: January 12th, 2014, 6:41
If you continue playing with terminal that way you'll brick the drive for good...
P.s. some features and parameters can be soft or hard encoded into firmware.
PostPosted: January 12th, 2014, 7:51
I've discovered the drive does not read very well, so the drive is only for playing around with. Not worried if I brick it.
PostPosted: January 12th, 2014, 13:14
SB FF does something, but not sure what, any commands sent after that is just garbage. Have to reset to get the drive to work again in putty.
SB FE Seems to do nothing but display E:0002 - Inv Prm. Here is a copy of the log.
1.5G Limited
SPW 1.5G Link Ok!
IS=+00005
Sp OK
H: +00000
Load
SK C: 000005D0
ENG>SRV>
SvoTbl Loaded
BD
ENG>SBxÈSb
SB FE
E:0002 - Inv Prm
E:0002 - Inv Prm
2àÎ`ø8þ`øøøþþþþþþþþþþþþ 1.5G Limited
SPW 1.5G Link Ok!
IS=+00000
Sp OK
H: +00000
Load
SK C: 000005BB
ENG>SRV>
SvoTbl Loaded
BD
ENG>Sb
E:0002 - Inv Prm
ENG>SB FEpÌÆ`ø8þ`øø 1.5G Limited
SPW 1.5G Link Ok!
IS=+00005
Sp OK
H: +00000
Load
SK C: 000005CA
ENG>SRV>
SvoTbl Loaded
BD
ENG>Sb
ENG>SB FE
E:0002 - Inv Prm
ENG>
PostPosted: January 12th, 2014, 13:19
Entering PK will park the heads. Here is a log of the drive while I was playing a AVI movie file off it.
1.5G Limited
SPW 1.5G Link Ok!
IS=+00000
Sp OK
H: +00000
Load
SK C: 000005C6
ENG>SRV>
SvoTbl Loaded
BD
ENG>pk
E:0001 - Inv Cmd
ENG>PK
ENG>Sb
Wk
Idl
Wk
ENG>ÿ¨KSb
Wk
Idl
Wk
ENG>PK
Sb
ENG>Wk
ENG>PK
ENG>PKSb
Wk
ENG>Sb
Wk - seems to wake the drive
Idl - seems to be the drive is Idle
Sb - seems to be Standby.
PostPosted: January 13th, 2014, 18:45
Anyway to run the drive through its self test stuff like with the Seagate drives. I want to know how healthy the heads are. I think the read heads are week, probably due to all the standby attempts its done.
shane
PostPosted: January 14th, 2014, 9:15
You can test heads for functionality but the problem may be the surface, so it is pointless. I see it hard to do without resources, though...
Users browsing this forum: Google [Bot], jabuzzard and 183 guests
