 Post subject: Dead Hard Drive?
PostPosted: January 16th, 2014, 11:41
Greetings all
Last November my C:/ packed it in (Seagate Barracuda 7200.10 , 250 Gb). Corrupt windows files. I replaced the HD. Yesterday I thought I might try to recover some of the files contained therein. I reconnected it, but when it's connected my computer will not power on. Can I assume the drive is only good for a paperweight now?
Thanks in advance for any help or insight.
 Post subject: Re: Dead Hard Drive?
PostPosted: January 16th, 2014, 12:20
spildit check pm please
PostPosted: January 16th, 2014, 13:36
To degrade from corrupt windows files to not powering on seems a bit strange. You can check the TVS, as was suggested. After that, you can trash the drive or have it assessed by a data recovery professional, if you want files recovered.
PostPosted: January 16th, 2014, 16:19
See http://www.users.on.net/~fzabkar/HDD/TVS_diode_FAQ.html
... and http://www.users.on.net/~fzabkar/HDD/ (photo clips)
PostPosted: January 20th, 2014, 9:43
Banned User
May be a wrong power input you try... Try victoria to proper diagnose the drive. File is attached.
Muhammad Ali
VCR446Free.rar [1.92 MiB]
Downloaded 342 times
PostPosted: January 20th, 2014, 12:09
Banned User
He power of the drive in perfect condition their is only a 1% chance the hard drive has lost the power. I think he reconnect the drive incorrectly.
PostPosted: January 20th, 2014, 19:44
Thank you all for your help. As per your posts, I did a little more research as to the TVS. From what I read, I can just clip the TVS off. Is this correct? This is going to be a one shot deal, so I only need the HDD working long enough to recover the files I need. I also found an image of my the circuit board
http://www.users.on.net/~fzabkar/HDD/ST3320620A_TVS.JPG
Which do I clip? the 5 volt or the 12 V? I am assuming the 12V because that is the plug I use to power it.
Btw, in response to one comment, I have been taking apart and putting back together my machines since my first one. I've never done a new build yet (that's next) but I know my way around the inside of a tower.
Thanks again.
PostPosted: January 20th, 2014, 20:56
@trevor999, clip whichever TVS diode is shorted, assuming that is the problem. My FAQ gives you detailed instructions on how to do this.
PostPosted: January 21st, 2014, 2:37
The circuit board appears normal. There are no burn marks or damaged components that I can see.
PostPosted: January 21st, 2014, 2:42
What do you "see" with a multimeter?
PostPosted: January 21st, 2014, 12:40
I don't own a multimeter (although I can probably borrow one). Never used one either. I'm just going by the previous comments re the TVS.
PostPosted: January 22nd, 2014, 1:21
Which plug are you referring to? You said the HDD was your C: drive, so I naturally assumed that it was internal, not external, in which case your statement makes no sense.
A cheap DMM costs US$5. Instructions for using it are in my FAQ.
Users browsing this forum: Google [Bot] and 218 guests
