Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2
 Post subject: Re: WD5000AAJS WD CAVIAR SE Drive suddenly died.
PostPosted: December 23rd, 2013, 14:14
I did apply flux to the ic's and then used a soldering iron to see if it was dry joints. Thats the first thing i did.
PostPosted: December 23rd, 2013, 15:19
Bingo... :mrgreen:
The problem, in any case, is elsewhere.
PostPosted: December 23rd, 2013, 18:28
Whys it bingo?
The fault was as described, The drive started getting better as I cleaned the board up and re soldered the pins on the ic's
If the drive is not detected by the bios to me indicates a pcb fault no? Either something has died due to heat or the solder has become dry or cracked..
Correct me if im wrong.
PostPosted: December 23rd, 2013, 19:49
In most cases, if a drive spins up but is not detected, then the fault is internal, either a head/media fault, or a damaged firmware module. Your PCB is a well known exception in that its Marvell MCU often fails in such a way that mimics a head fault.
PostPosted: December 24th, 2013, 1:24
atomical wrote:
Whys it bingo?
In this case to me it is another story, but only a diagnose can tell.
P.S. the story about the MCU that makes the drive act as it has a head fault happened to me only less than 10 times in several thousands similar drives processed and there were also other problems. On 2 , only the read channel was affected and the rest was operational, only on 2/3 it has been possible to restore functionality but no data was needed , refurb only (don't know after many years if the drive is still on). These are my stats.
PostPosted: January 5th, 2014, 17:53
Thanks for the offer Spildit. A little too far to send over but thanks any way.
PostPosted: January 16th, 2014, 19:03
Does anyone have the firmware and rom for this drive?
WD5000AAJS - 32YFA0
The PCB board rev is 2061-701477-900 04P XW 4V05 C8AR 4 0005030 8035
Not fussed if i mess it up as I had a back up of the photos so just want to see if I can recover anything myself. Have a play ;)
Users browsing this forum: Google [Bot] and 61 guests
