 Post subject: Seagate ST3250318AS clicks 11 times then spin down
PostPosted: January 22nd, 2014, 2:30
I have a Seagate ST3250318AS (FW HPG7). When I plug it to PC3000 and power on SATA, the drive clicks 11 times then spin down.
When I access the terminal, I get the output bellow:
Rst 0x08M
No HOST FIS-ReadyStatusFlags 2002B001
When I click on CTRL+Z, I can access T>:
ASCII Diag mode
F3 T>
I suspect a firmware issue but I don't think it's a BSY or LBA0 issue.
Can anyone help with this issue please.
Kind regards.
 Post subject: Re: Seagate ST3250318AS clicks 11 times then spin down
PostPosted: January 22nd, 2014, 2:44
You can do also Ctrl-R (Online mode) to show some messages as it is running and NLINE), and Ctrl-A (when in DIAG mode) to show some drive info
There were a few google hits for that term msg.
did you attempt the BSY or LBA 0 fixes, as this is a 7200.12 and the 7200.11 tutorials should NOT be followed
PostPosted: January 22nd, 2014, 3:00
Thank you for your help.
Ctrl-R and Ctrl-A didn't show anything.
I didn't try the BSY or LBA0 fixes yet but I'll keep searching for a solution for the 7200.12
PostPosted: January 22nd, 2014, 3:08
I tried this:
F3 T>
ASCII Diag mode
F3 T>/2
F3 2>Z
HighPowerMode
Spin Down Complete
Elapsed Time 0.103 msecs
F3 2>U
HighPowerMode
ExecuteSpinRequest
DiagError 00006008
Spin Error
Elapsed Time 15.461 secs
R/W Status 2 R/W Error 84150180
F3 2>/1
F3 1>N1
Failed to load overlay 00000004
LED:000000CC FAddr:0028751
Rst 0x08M
But unfortunately, it didn't work. the same sound 11 times then spin down.
PostPosted: January 22nd, 2014, 3:47
Heads are bad 99% for sure.
PostPosted: April 23rd, 2014, 16:55
I have exactly the same. Really do you think is heads?
PostPosted: April 24th, 2014, 10:40
the drive clicks 11 times then spin down = bad heads
PostPosted: April 24th, 2014, 13:16
Bad heads.
Data Recovery Cape Town
PostPosted: April 27th, 2014, 13:46
lol. That make things really clear
Thanks for the help :D
PostPosted: April 28th, 2014, 17:27
Nick_CT wrote:
Bad heads.
Spildit wrote:
Pre-amp or heads.
Head stack replacement inside a hepa 100 asseptic room is required.
Drive can't read at all from platters.
Also the drive is giving me an error through a firmware tool i have never seen this before.
Boot 0x40M
Spin Up
FAIL Servo Op=0100 Resp=0007
ResponseFrame 0600 0079 06CC 2F00 0008 0000 0000 0000 0F67 0000 0000 0000 0000 0000 0000 0000 9EB7 E8B8 FFFF 2000 24B4 0000 0000 4C35 0000 4C35 FFFF 2247 0000 0020 001E 0007 0010
FAIL Servo Op=0100 Resp=0003
ResponseFrame FE80 0077 06CC 2F80 0008 0000 0000 0000 0F4C 0000 0000 0000 0000 0000 0000 0000 9EB7 E8B8 FFFF 2000 24B4 0000 0000 4C35 0000 4C35 FFFF 007F 0000 0020 001E 0004 0000
ResponseFrame FE40 0077 06CC 2F80 0008 0000 0000 0000 0F4C 0000 0000 0000 0000 0000 0000 0000 9EB7 E8B8 FFFF 2000 24B4 0000 0000 4C35 0000 4C35 FFFF 007F 0000 0020 001E 0004 0000
ResponseFrame FEC0 0077 06CC 2F80 0008 0000 0000 0000 0F4C 0000 0000 0000 0000 0000 0000 0000 9EB7 E8B8 FFFF 2000 24B4 0000 0000 4C35 0000 4C35 FFFF 007F 0000 0020 001E 0004 0000
ResponseFrame FEC0 0077 06CC 2F40 0008 0000 0000 0000 0F59 0000 0000 0000 0000 0000 0000 0000 9EB7 E8B8 FFFF 2000 24B4 0000 0000 4C35 0000 4C35 FFFF 007F 0000 0020 001E 0004 0000
ResponseFrame FF00 0077 06CC 2F40 0008 0000 0000 0000 0F59 0000 0000 0000 0000 0000 0000 0000 9EB7 E8B8 FFFF 2000 24B4 0000 0000 4C35 0000 4C35 FFFF 007F 0000 0020 001E 0004 0000
ResponseFrame FEC0 0077 06CC 2F00 0008 0000 0000 0000 0F67 0000 0000 0000 0000 0000 0000 0000 9EB7 E8B8 FFFF 2000 24B4 0000 0000 4C35 0000 4C35 FFFF 007F 0000 0020 001E 0004 0000
ResponseFrame FE80 0077 06CC 2F40 0008 0000 0000 0000 0F59 0000 0000 0000 0000 0000 0000 0000 9EB7 E8B8 FFFF 2000 24B4 0000 0000 4C35 0000 4C35 FFFF 007F 0000 0020 001E 0004 0000
Users browsing this forum: Google [Bot] and 224 guests
