 Post subject: WD3200BPTV-24JJ5T0 spin well but can't read SA
PostPosted: January 22nd, 2014, 12:26
I've a WD3200BPTV-24JJ5T0 drive. it spin well, no clicks.
When I connect it to PC3000, it can't read ID even in Kernel mode:
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 2
Cyl Count............................... : 256
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 256 Kb
ROM version............................. : 65.48K
ROM generation.......................... : 65.48K
Link table version...................... : 05.0H.
Consolidated ROM version................ : 00650048
ROM Modules:
Flash ROM dir reading................... : Ok
SA regions address...................... : by default
SA Translator loading................... : Ok
[b][color=#FF0000]SA defects assigned..................... : 2[/color][/b]
Heads configuration..................... : by map
Heads number in use..................... : 2
Switched off heads...................... : No
Heads map............................... : 0,1
ROM Firmware version.................... : 00650048
When I try to read modules by ABA, I get the output bellow:
Module search process started
Search method........................... : Search by ABA
ABA..................................... : 0
Size in sectors......................... : 168 148
ABA 0 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 1 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 2 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 3 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 4 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 5 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 6 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 7 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 8 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 9 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 10 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 11 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 12 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 13 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 14 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 15 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
Modules found........................... : 0
Module search process completed
Could it be a Bad Head that should be replaced?
Kind regards,
Users browsing this forum: Zack Lai and 79 guests
