 Post subject: Hi Need LDR for WD2500AAJS-00YZCA0
PostPosted: February 5th, 2014, 12:29
Hello ,
Need LDR for WD2500AAJS-00YZCA0 Thanks in advance
>Techno mode key
>Techno mode key......................... : Ok
>RAM:
>HDD Info reading........................ : Ok
>Heads number............................ : 1
>Cyl Count............................... : 256
>ROM:
>ROM reading............................. : Ok
>ROM Data size........................... : 192 Kb
>ROM version............................. : 03.54B
>ROM generation.......................... : 03.54B
>Link table version...................... : 05.02.
>Consolidated ROM version................ : 00030054
>ROM Modules:
>Flash ROM dir reading................... : Ok (Active)
>Flash ROM dir reading (Ext)............. : Ok
>Modules directory address............... : 74 742
>SA regions address...................... : by default
>SA Translator loading................... : Ok
>Heads configuration..................... : by map
>Heads number in use..................... : 1
>Switched off heads...................... : No
>Heads map............................... : 0
>ROM Firmware version.................... : 00030054
Users browsing this forum: No registered users and 120 guests
