 Post subject: st3500630as PCB board testing help
PostPosted: February 11th, 2014, 8:35
Hi
I have a st3500630as PCB board that was working and the drive was to with a faulty 3r3 inductor but when I got this replaced by a trusty repair guy in a TV repair shop it powered on with beeps but then the inductor had come off for what ever reason
I would like to know is there any test that I can do until I receive a replacement inductor to make sure that the PCB is working so I do not waste time in soldering a new inductor
I will really appreciate any help
 Post subject: Re: st3500630as PCB board testing help
PostPosted: February 11th, 2014, 8:53
is there no testing that can be done
I am an engineer and very competent with a multimeter
A replacement PCB is out of the question
PostPosted: February 11th, 2014, 15:28
Spildit wrote:
Buy a new pcb and pray for the pre-amp to be ok.
P.s. - Prayers are for free.
i totally agree
P.S.
i'm an electronic technician, i'm very competent with a multimeter too
My firmware database:
PostPosted: February 11th, 2014, 16:16
there must be test points on the pcb
PostPosted: February 11th, 2014, 16:57
If you know test points to compare you can guess where the problem might be, but you already have a known problem (the inductor) so you need first to find a replacement for it then you can check voltages points.
However you need to know which are those test points, the best guy in the forum for test points is 'fzabkar'
Users browsing this forum: Google [Bot] and 65 guests
