 Post subject: Seagate ST9750420AS unLock[ed]ing help Request
PostPosted: February 14th, 2014, 14:54
I have a hdd that i need to gain access to.
Drive Details,
sudo hdparm -I ata-ST9750420AS_5WS3PP0P
ATA device, with non-removable media
Model Number: ST9750420AS
Serial Number: 5WS3PP0P
Firmware Revision: 0002DEM1
Transport: Serial
Security:
Master password revision code = 22616
supported
enabled
locked
not frozen
expired: security count
supported: enhanced erase
Security level high
My details.
Dell XPS L1501 laptop replaced with custom built laptop via insurance upgrade option.
I retained the 750GB Hdd when the xps was sent off along with a 1TB drive that was in a caddy where the dvd used to be.
USB data case allows new laptop to see Seagate hdd but wants to format it.
Placing the hdd in a spare sata port in the new laptop brings up a prompt at bios to enter password.
a number of failed attempts later the hdd says its locked and booting continues to the primary drives in the new laptop.
I know my password. Well sort of. The password was in two parts. A word I entered then a keypress/hold on a yubikey.
The yubikey is set to produced a static output of characters [68 i think].
When I was using the xps i would enter the human part then hold the yubikey and release.
characters would enter the keyboard buffer until it beeped [presumably overflow of the buffer].
I have tried to enter a total of 32 characters with hdparm as
sudo hdparm --security-mode h --user-master m --security-unlock xxxxxxxx[32max] ata-ST9750420AS_5WS3PP0P
but only get an error;
SECURITY_UNLOCK: Input/output error
What I want.
I want to be able to mount the disk so that i can copy parts of it off to another disk, prior to secure formating it.
I will need to be able to interact with the drive such that I can get at the truecrypt partition on it [i know the password for that].
I tried googling for a bit, hence the hdparm and being here.
I also tried a cd i have labled mhdd32 v4.6.
However mhdd got me no where, as the seagate disk was seen but not ready or something similar.
can someone contact me to help me with this problem ?
Neil
 Post subject: Re: Seagate ST9750420AS unLock[ed]ing help Request
PostPosted: February 14th, 2014, 16:28
@fzabkar
The link to zu.exe, works but is that exe for a 32bit system? it will not run on my 64bit windows.
Also it is a windows exe, my posting did not mention windows, it refers to ubuntu type os.
i am guessing at this point that what i need are the keyboard scan codes for the xps, if i am to solve via entering the correct password ?
PostPosted: February 14th, 2014, 16:48
Thank you for your kind offer but I would not like to ship my hdd.
PostPosted: February 17th, 2014, 22:50
Well this all seems to have gone quiet.
My problem still remains.
Users browsing this forum: pepe and 42 guests
